Fortes's in my future ???
zebra03
All Audio - NO BS
I think I am going to look at some old Forte speakers tomorrow ( the owner says there is no tag on the back ) . He says it has small horn and mid horn and a woofer . He also said it has magnets that hold on the grills . This made me wonder since I have KG4's and they do not have magnets holding the grills . Any other advice I need before I go ? Thanks By the way he wants $250 for the pair plus Sony receiver and CD player .
Well, the Heresy I, II and III have mid horns as do the Cornwalls. I believe the Heresy III had grills held by magnets as do the Cornwall III's. Heresy II and Cornwall II used velcro as I recall. The Quartet is a great sounding speaker which uses a 10" woofer and 12" passive radiator for the low end, Tractrix horn mid range and the standard K-70 something tweeter. In smaller to mid size rooms, the Quartets can hold their own. Much better low end than the Heresy in my expereience.
Thanks again . I am writing down dimensions from the Klipsch website so I can try to figure them out since there is no label on the back . He said they are over 30 inches tall so I think I can rule out Heresys's .
Hope for Forte II's but be satisfied with Quartets. One clue would be the passive radiator in the back panel, if there is one. 15" passives on the Forte II, 12" on the Quartet. Both are great sounding speakers.:yes:
The guy measured the woofer at 11.5 inches and said there was a passive in back . I'm hoping for Forte .
The original Forte' had a 12" passive radiator but the grills were attached via pins on the frame into rubber gromets on the front baffle. If the grills on his speakers are attached via magnets they are very likely to be Quartets which isn't a bad thing. I would have him measure the woofer. If it's approx 10 inches, I will bet lunch they are Quartets.
Quartets are very nearly Forte' II so...hope you get what you're looking for and I bet you'll be happy with either...
Bill
And no, you dont have to immediately start ripping out drivers and remodeling the effin crossover. They usually sound great just the way they are.....:D
Time is not on your side...
I am sure the speakers (what ever they turn out to be) will work and sound just fine. That does not mean that they are fine. While the plastic caps are probably ok the electrolytic in the bass section are possibly 22 years old. That is not a good age for medium quality 1990 vintage capacitors. So if you are going to change out the woofer section caps you may as well change out all the caps for high quality ones at least and you can forget about them for the rest of your life if you want to. People tend to forget about stuff like this so putting in new ones when you buy a twenty plus year old set of speakers is just good smart thinking. The same goes for buying vintage amplifiers especially tube units with their higher voltages. Best regards Moray James.
I routinely recap amps. Probably when I dont need to, also. But they are subject to heat, etc., and my own experience with this particular speaker and ones similar is that the caps are good for a bit more than 20 years. Admittedly, mine have been in climate control the entire time. But I have also driven the heck out of 'em....
The replacements are not expensive, but some people find it to be a pain in the arse to get at them and do the job...
Well now , the earth moved , the angels sang , I think IT moved . Forte II ! Consecutive serial number's . Oak veneer . I talked him down 10% . I also got
Sony STR-D1090 receiver 120w x 2
Sony CDP-C450c 5 disc CD player
Sony TC-WE305 Dual well cassette deck
Pictures coming
Smell of Winston . Got the cabinets clean . How do you get the smoke smell out of the grill cloth ? Oh and some crayon on one grill cloth . How do you get rid of that ?
Good call .
Pictures coming
Good job! take the grills off and let em air out outside, or dust baking soda on them and vac it off. or just wait....lol
