Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Speakers
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 03-07-2012, 07:15 PM
bluesky's Avatar
bluesky bluesky is offline
AK Member
What causes speakers to sound 'boomy, not clear, muddy'?
I have an extra spare pair of 1970 Sansui SP-2000 in the closet. I don't believe that they have ever been used or even taken out of the box, until I took them out and tried them last year. The cabinets are factory fresh in the original wrappings with all associated paperwork.
1970 Sansui SP-2000.
1 super tweet
2 tweets
2 mids (AlNiCo magnets)
1- 12 inch woofer(AlNiCo magnet)
The problem is that the speakers sound really boomy, undefined dull base response, not clear, or maybe the term is very muddy. To put it bluntly, they sound really bad. Like, there is something wrong! Big time.
With that said would the problems be deteoriated caps (maybe from not ever being used), woofer problems (like voice coils), or something else like a corroded L-pad type dial pots?
I do want to restore the speakers to spec, for fun and the basic education on speaker restoration, because the cabs are Mint, not even a fingerprint on em. And I like the sound of SP-2000s. I know there is better speakers out there but the SP-2000s are fine for me.
Any information or advice, no matter how small, would be most welcolme.
Thanks guys!
The SP-2000s below are just a generic photo off of Yahoo Image.
  #2
Old 03-07-2012, 07:24 PM
Copa1934's Avatar
Copa1934 Copa1934 is offline
My ears are bleeding
1 super tweet
2 tweets
Thanks guys!
Start with some packing or stuffing the port. Many people have found filling the port or making it smaller helps tighten things up.
__________________
RS-1080, SX-680, 9090DB, STA-2500, STA-860, RX-V795
RS 40-4024a, 5b, 7b, Min-7, LX-5II, JBL L3, L88, HPM-40 (2nd Gen), Infinity 4000, Allison CD7, Advent1, V.A. Haydn (first Gen)
Sony DVP NS755V, Technics SL-1700, Sony WEGA DLP 60"
  #3
spkrdtr's Avatar
spkrdtr spkrdtr is offline
spkrfixer
The first thing I would do is the toilet paper tube test to make sure every driver is putting out sound. I suspect some of yours may not be. If so, next tackle the pots with some de-oxit spray, then caps last.
__________________
It's all about the music
Carl
Carl's Custom Loudspeakers
  #4
Old 03-07-2012, 07:29 PM
RayW's Avatar
RayW RayW is offline
Parrothead with a badge
Probably the 2 leading causes for that are Alnico magnets and the Sansui badge on the front.
I would start with positioning. Get them away from walls/corners and off the floor. See what that does. After that, check for air leaks. Having a leaky box can futz with the tuning. After that, I'd check cabinet bracing. Weak side walls can add to the boom. Then I'd go with stuffing as Copa suggested.
If you have a schematic of the XO we can see if there's reason for concern there. I'd recap it anyway but usually there isn't a cap in line with the woofer so it wouldn't affect boominess.
__________________
You can find me where the music meets the ocean
If you get the notion
Stop on by and play a while
-Zac Brown
  #5
bluesky's Avatar
AK Member
Quote:
Will do. But it's not really a port problem. It's the actual woofer sound, very bad, very dull, and boomy, like boom, boom, boom. Like that. I have another pair of SP-2000s that I am using that sound really good so I do know the speaker model very well.
Quote:
I was going to DioxiT the pots first. I remember a guy here on AK saying a long time ago to do that first and that may solve the problem, all the speakers will then fire up.
1. What is a: " toilet paper tube test "? How do you do that. I will do it.
2. Do you think it could be a bad woofers?
Thanks guys. I really super appreciate it.
Audiokarma
  #6
Old 03-07-2012, 07:43 PM
bluesky's Avatar
AK Member
I'll try taking the Sansui badge off. Think that would work??!!
It's not positioning, it's definately the speakers, both of them. It 'readily apparent' as soon as they are energized, they are singing "I am broken".
The speakers are ported, not acoustic suspension. The big port is like 2.5 inches or so.
I'll check the bracing too but I'm sure the bracing is fine, but I will certainly check it.
I don't have the schematic of the XO but I have drawn one up myself but haven't opened up the speakers yet to finish the drawing. I do know exactly what caps I need, and their values, from other AK Sansui members.
  #7
Old 03-07-2012, 08:04 PM
whoaru99 whoaru99 is online now
Part-time Iconoclast
Room issues and sub-optimal woofer/cabinet/port tuning are the most likely causes.
  #8
Old 03-07-2012, 08:06 PM
spkrdtr's Avatar
spkrfixer
From your OP, it seems you have no highs. So, you need to find out if your mids and tweets are working. Take a toilet paper or paper towel tube and place it close to the driver your testing whilst playing music and listen for sound coming out of that driver your holding the tube up against. In particular, tweeters don't put out much sound so the tube test helps.
Yes, you could simply have bad woofers as RawW pointed out.
__________________
Carl
  #9
Old 03-07-2012, 08:22 PM
RayW's Avatar
Immensely!
There are actually higher pressures developed in a ported box than sealed. It seems counterintuitive but it's real. A leak in a ported box changes the tuning so dried gaskets or something like that can mess up the sound.
Carl makes a good point about checking the HF drivers. Not having highs makes the lows sound bad. The toilet paper tube thing is basically a low cost, low tech stethoscope. It'll give you an idea of what's what with each driver. If the caps are degraded so that the HF drivers aren't driving it'll mess up the overall sound.
__________________
-Zac Brown
  #10
Old 03-07-2012, 08:50 PM
Grainger49's Avatar
Grainger49 Grainger49 is offline
Old Fart
Of course the midrange might be poorly designed, too inefficient or damaged; this would give it a muddy sound.
Often the bass is where the mud gets mixed. One part bass hump and one part early roll off of the midrange. You get a hole and a hump and it sounds pretty bad.
In general I like to accuse the crossover. The speaker elements are usually pretty good but the crossover doesn't use the drivers in the right range, or roll off too steep/too slowly.
__________________
"Remember, you are the only one who needs to be happy with the sound of your system."
Grainger Morrison
Audiokarma
  #11
Old 03-07-2012, 09:26 PM
puppet puppet is offline
AK Member
Anybody know if the factory broke in the drivers first? I'd give them a couple weeks on a thread mill.
  #12
Old 03-07-2012, 09:47 PM
PioneerGuy75's Avatar
PioneerGuy75 PioneerGuy75 is offline
Certified Lurker
Quote:
I might add that too many drivers can cause muddiness and poor imaging...
Read: KABUKI
__________________
“Music washes away from the soul the dust of everyday life.”
  #13
Old 03-07-2012, 10:13 PM
budgetaudio6's Avatar
budgetaudio6 budgetaudio6 is offline
AK Member
if they have tone controls wiggle them alot. A good cleaning as others mentioned. And it kinda sounds like dried out caps from non use. But ive read that they tend to charge(for lack of a better term) up and allow sound through.
Good luck with them.
__________________
Go on go in!
http://www.flickr.com/photos/budgetaudio6/
  #14
Old 03-07-2012, 10:31 PM
1TUFSS's Avatar
1TUFSS 1TUFSS is offline
Thread Killer
Toilet paper tube's the way to go. A lot of big 70s speakers used crude crossovers which more often than not didn't even bother rolling off the higher frequencies on each driver, making it damn near impossible to pick a dud driver.
Not only that, you could even have dead mids/tweeters and the woofer would still be producing these frequencies as best as it can...
__________________
technics SU-7700 / ST-7300 / RS-615 / SL-1200MK2 / ortofon 2M red / custom speakers / 2x YST-300 subwoofers / objective DAC / eighties speed metal
  #15
Old 03-08-2012, 01:17 AM
bluesky's Avatar
AK Member
Thanks guys,
I will try 'everything' you guys mentioned above. I really like the toilet paper roll for listening. Bet it works like a charm.
The SP-2000 crossovers are not easy to recap because of the size of the new caps, being larger... but it can be done.
Again, I really appreciate all your help.
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
©Copyright 2002-2015 AudioKarma.org, All rights reserved.
