moray james
Here is something you can try with your Heresy or any other speaker for that matter. I suggested to my brother to get some quality wool felt to do some surface damping on a pair of H3. So he picked up some real acoustical felt SAE F-11 rated which is 90% purr wool. We got 1/8 inch and 1/4 inch thick felt sheet. We applied the 1/8 inch over the face flange of the tweeter and mid horn and I placed 1/4 x 1/4 inch strips just inside the mouth opening (vertical) of the tweeter and mid horn. These additions have a very nice affect on how the speakers sounds stage and image being much improved.
This all got me to thinking about a twelve inch woofer crossing over to a small size mid horn (K701). The woofer is a large are drive when you think about crossing over at 750Hz and you are bound to get irregular interference between the mid horn and the woofer. So back to the SAE F-11 wool which is acoustically the most transparent available with the widest possible damping coefficient. I used a 1/4 inch thick layer cut out to fit into the woofer opening of the grill frame. The bass frequencies glide right through the wool felt as it was not there but the higher frequencies close to crossover and above are diminished. This leaves the mid horn to do its job without competition from the large radiating area of the woofer.
I initially did all this work with some high density fiberglass and then with some craft felt. I can assure you that buying SAE rated F-11 wool felt is the way to go and well worth the $30.00 it cost to do a pair of Heresy 3 or any other speaker. I plan to do the same on my KLF20 in the near future. Best regards Moray James.
