ymarko
It seems that replace this tracking roller (O-ring) is a very common service for ST-6 and ST-7 Rabco tonearms.
So after a year of postponing, today I got into this project. Sure enough the old rubber roller is disintegrated, totally gone. Other then that, TT seems to operate fine. Both belt are fine.
1. How to get to this roller? I removed a couple of pieces from the top, and I see it (the place where I need to install the new one). However, the whole Rabco tonearm is sitting around the tracking shaft and I don't see how to get there. What is the correct approach to get there? From top? From bottom? Need help.
2. How to remove the platter (to check the condition of the drive belt)? Normally I pull them up, but this one is sitting tight and I don't want to force it.
