Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Solid State
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 04-17-2012, 05:06 PM
hpm-1000 hpm-1000 is offline
AK Member
Cool Electrocompaniet aw-100
hi,
I have a electrocompaniet aw-100 (two times 100w) driving my hpm-1100s, but i wonder how this would sound with something a bit more powerful so i have the chance to get another ec aw-100!
The problem is that this are not bridgeable! So i wonder if there is a point on having each one driving only one speaker?? it should be easier for the amp, no?
Or is there any other way of bridge them??
thank you!
  #2
Old 04-17-2012, 05:22 PM
Jon_Logan's Avatar
Jon_Logan Jon_Logan is offline
AK Member
If the amps have a common ground output and work well into lower impedances, I'd say they are bridgeable.
These are the Matti Otalla, low TIM amps. I've only worked on two. It was a long time ago, but I believe they were common output grounded. To check, make a continuity check between Right '-' speaker output and Left '-' speaker output, with the amp off. If there's continuity there, they should be bridgeable.
If your speaker are 4 ohms, or higher (preferably higher), they should be fine on that amp bridged.
You'll need to buy some bridging adapter.
So, it looks possible, but it's only going to buy you 3dB of output power (6db output voltage). If volume is what you need, it might be a good time to consider more sensitive speakers.
... although HPM-100's were fairly sensitive, I thought.
  #3
Old 04-17-2012, 05:30 PM
AK Member
thanks, i am not sure i understand how to do that continuity test?
Its not volume in itself , i am looking for a bigger soundstage, perhaps more dynamics , more power, i am not sure, just wonder how this speakers would sound with more power.
my speakers are 6.3 ohm
  #4
Old 04-17-2012, 07:50 PM
Guest101 Guest101 is offline
AK Member
I think your AW100 is dual mono designed amp with a separate transformer and power supply for each channel so there is no advantage to use one amp per channel ... Unless you rewire your HPM1100 speakers with bi-wire connections with the woofer connected to one set of speaker binding posts and the mid/highs on the other set of binding posts. This way you can vertical bi-amp your speakers w/ one amp per speaker using one channel for the mid/highs and the other for the lows. This would be a big step up.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
