FOR THOSE SHIPPING SX 1010's and other LARGE RECEIVERS
Due to the location of the POWER SUPPLY BOARD and close proximity of the bottom panel, and the rising amount of threads of shipped 1010's that have broken POWER SUPPLY BOARDS, due to being dropped by the "GORILLA's" at UPS and or FEDEX, this thread is offered as one solution to the problem. I recently shipped my SX-1010 via the "GORRILA's in BROWN" from Md. to FLA, and it arrived with the usual bumps and bruises to the outer box, but the internal box, and the 1010 were un-affected.
Get a 3/4" plywood Handi panel from Home Depot or Lowes cut to the width of the bottom panel and the depth of the complete unit. Don't use regular boards edge glued to give you width. It WILL BREAK at the glued seams. The 3/4" plywood has the strength to resist most everything UPS and FEDEX can throw at it short of falling out of the plane at altitude or a forklift running over it.
Remove the bottom panel, and remove the feet, bagging the feet and 1/2 of the attachment screws.
Align the front edge of the plywood with the bottom panel on top with the outer side of the panel facing the plywood. Mark ALL panel attachment holes and 4 of the feet holes. the feet holes go ALL THE WAY THRU!
The Front of the Plywood MUST BE ALIGNED with the FRONT EDGE of the BOTTOM PANEL. It MUST NOT BE ALLOWED TO SIT ON THE FRONT FACE PANEL! With a 3/8" bit countersink all of the panel attachment screw holes marked on the plywood. This will allow the screw heads to set inside the holes and the plywood to sit FLAT on the bottom panel. See pic. Panel screw holes in red, feet holes in yellow.
Attach the bottom panel to the unit. Then with the 4 screws from the feet, attach the plywood to the bottom panel. The plywood will overhang the BACK of the unit about an inch. This is to help protect the antenna and other items sticking out. Also gives styrofoam sheet a place to sit while wrapping with bubblewrap.
Use Doublewalled boxes. I used a combination of Large BUBBLE bubblewrap, a 10 pack of 12"x4' styrofoam sheet, and packing tape. Pack the styrofoam sheet in tight. MOVEMENT inside the box is DEADLY! Take the knobs off, INCLUDING THE TUNER KNOB! baggie them, then impale the lower 1/2 of the front on 1 sheet, then the tuner dial with another, then a larger full sheet over that will protect the push buttons in the middle. You DON'T want any pressure on these at all. They must float inside.
Also pack a single layer around the RCA's, spkr jacks, and antenna, then another full sheet. Bubble wrap all of this tightly. Then insert into the 1st box with 1" of blocks in the corners to let the 1010 sit on the corners. These can be part of the sides. But must not be a solid bottom. You want some space between the box and the plywood. The sides, front, back and top pack solidly with sheet. Close up box with heavy tape and SHAKE. If you feel movement, undo and REPACK. It MUS NOT MOVE INSIDE! Prep 2nd box.
2nd box. If you have corner blocks from something else USE THEM. If not, a single layer of sheet with another layer at the lower corners. Then the box in the middle. Once the box is centered, pack sheet tightly around it on ALL sides to FULL! NO SPACES, NO MOVEMENT! TAPE HEAVILY! Then roll the box gently. If you can feel movement, open it up and try again. You want absolutely NO MOVEMENT!
It takes a lot to pack one of these so it'll survive the trip. It ain't cheap either. And it's worth it to not get a PM or Email from the new owner saying "it's got a crack or broken power supply board. UPS/FEDEX/USPS dropped it". It should be worth it to the new owner to get it in one piece also.
This also applies to other gear.
