Thorens TD-150 project part two
Divotdog
"I can fix it Grampa"
A couple of years back I restored a Thorens TD-150 in this thread, I used it for awhile in the garage system where it worked very well, I tried it in my main system but it didn’t quite reach the level of my modded TD-145, so back out to the garage it went.
picture.php
I set some goals for the mod of the TD-150, I didn’t want any switches on the top plate, I want it to be very easy to mod it further, I wanted clean lines and a little bit bigger than the original 150, I also wanted to be able to change the tonearm board from the top of the table.
With this in mind I made some drawings to figure out just what size it was going to be.
attachment.php
The lower one is the actual size of the profile.
attachment.php
The table is essentially the same depth as the original and just a hair wider to accommodate different arms.
First up I fabricated a new top plate out of 5056 ¼ aluminum sans speed control and tonearm lift holes.
picture.php
Next I machined a new plinth to the above specifications from laminated Finnish Birch plywood
picture.php
I then machined a bottom plate from ½ inch Baltic Birch plywood, the corresponding angles machined into the bottom plate were Mrs. Divotdogs idea, she is darned handy to have around!
picture.php
Next up were the top plate supports, again laminated Finnish Birch plywood topped with a layer of cork, I made the supports considerably larger than the stock support, I’m no engineer it just seems to me that this will keep resonance down, we will see.
picture.php
Here is a test fit of the suspension and the top plate.
picture.php
Another test fit with the platter installed and an armboard blank.
picture.php
Some of these photos are old as we move on you will see some minor tweaks that I have made, this project has been ongoing for well over a year now, but now I’m getting excited so it is stating to pick up pace.
And here we are after spending the last couple of days applying the Black Walnut veneer.
picture.php
[/IMG]
Looks like it's time to drop by the ole Divotdog workshop again. I love the look of the bottom angle of the plinth!!
That top picture brought back some memories of the all tube garage system, sounds much better in your living room though.
I applied a coat of Watco Danish Oil last night, I think I like the way this is looking, we will wait a couple of days and then start to apply a gloss poly coat.
picture.php
I have some time while I wait for the Danish oil to cure, so I decided to knock another goal off the list, I found that I was able to tap the existing armboard holes in the subchassis with an 8-32 Tap, the armboard can now be removed from the top of the table!
picture.php
I'm good and enjoying it immensly!
Thanks,
Jim
Thanks for pointing that out to me Shelly!
I have a very nice piece of Burled Maple that I am looking at for the armboard, and I am still tossing around some ideas for the top plate.
Very nice job! This post is timely for me as I just received a TD-150 that I am going to build a plinth for. It gives me some ideas. I promise not to copy!
Well, here we are a week into the finish process, gloss coats are slow and a pain in the a**.
picture.php
Another angle.
picture.php
I like the way they come out though! Another week or so of sanding between coats and we will be there.
