Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Digital Formats & Music Server Forums
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #31
Old 05-18-2012, 03:12 AM
SoNic67 SoNic67 is offline
AK Member
Just an example of what it should have the output stage - look inside my Denon DVD-2930.
The lower board is the DAC part. You see the DAC chips (right side), followed by two OpAmps and a bunch of capacitors. At the end (left side) there are the muting (anti-popping) transistors.
  #32
Old 05-18-2012, 05:16 AM
pete_mac's Avatar
pete_mac pete_mac is offline
Blood type = AU Alpha
Quote:
Originally Posted by SoNic67 View Post
That looks promising, but I don't see on the board any serious OpAmps on RCA outputs, so I am not convinced of the final audio quality.
I'm in the other camp completely. Discrete output stages are the way to go for quality output from a DAC, not opamps. IMHO opamps are a compromise where the designer doesn't want to go to the effort (or expense) of designing a proper output stage, and the picture of the output stage that you've posted above is a perfect example of such a compromise.
__________________
SB Touch > audio-gd DI + Tentlabs XO > tweaked audio-gd DAC 3SE > Sansui AU-X701 / AU-719 > Focus Audio FS68
  #33
Old 05-18-2012, 05:43 AM
pete_mac's Avatar
Also, it is worth noting that this DAC uses a PCM5102 which is a voltage output DAC rather than a current output DAC, therefore it uses no I/V stage and does not require opamps nor a discrete output stage.
Based upon the above, it's a bit harsh to write-off the Dragon based upon assumptions made after viewing a photo
__________________
  #34
Old 05-18-2012, 05:42 PM
AK Member
I don't see any OpAmps on the RCA outputs for that DAC. Even if you are right about the DAC, the PCM5102 has a THD+N of -93dB (with a possible worse case scenario of -83dB). Not even 16 bit real audio quality (that would be -96dB). Sure, it can "gulp" 32 bit, but the analog side is not capable of more than 15-16 bit... the rest to those 32 bit is plain noise and distortion.
The PCM5102 needs on output a load of 10kohm or more. Less than that and the output is garbage. You need at least a buffer there, for those headphones.
As for OpAmps: You need reconstruction filters at the output. You need virtual ground impedance of curent output DAC's. You need a buffer for following stage/headphones.
None of this can be done properly without an OpAmp. All the DAC manufacturers show analog stages with OpAmps in their falsgship DAC datasheet pages. This include Texas Instruments, Analog Devices, Asahi Kasei, Cirrus Logic, Wolfson Micro, ESS (Sabre)...
  #35
Old 05-18-2012, 09:07 PM
pete_mac's Avatar
Sorry but I disagree. None of my audio-gd DACs have opamps full-stop... They are discrete all the way. They are sonically excellent without an opamp in sight. Can I suggest dropping Kingwa an email and telling him to replace his discrete output stages with opamps? I'd love to see his reply. . There are many ways to skin a cat.
Again, I'd strongly suggest investigating the above DAC chip and overall DAC architecture before publicly writing-off a DAC based upon speculation and assumption. In my personal experience Musiland make excellent bang-for-buck gear. They are not some 'fly by night' company trying to sell crap products, and rest assured that their engineers are not stupid nor oblivious to the requirements of designing a DAC.
__________________
Audiokarma
  #36
Old 05-19-2012, 05:50 AM
AK Member
You go by what Musiland engineers do, I go by what TI/BB, AD, AK, WM, CL, ESS engineers do.
As for discrete stages instead of OpAmps... they are poor implemented in 80% of cases (exception is maybe John Hardy 990C ones) and perform below of the level of a modern OpAmp. Been there, done that.
In the end... I agree to disagree.
  #37
Old 05-19-2012, 05:59 AM
pete_mac's Avatar
Indeed, we can agree to disagree regarding what it best. Each to their own
However, if you had checked the spec sheets of this DAC chip, you would see that there is no need for opamps with the PCM5102 (as I mentioned earlier) hence Musiland are in the right and deserve none of your criticisms regarding improper design. Musild have designed it EXACTLY in accordance with the TI specification sheet. They are not stupid! I think it is important that this assertion is corrected, as I'd hate for a potential purchaser of this budget DAC to do a google search for information, find this thread, and assume that there is some flaw in the design of this DAC (which is clearly not the case).
http://www.ti.com/product/pcm5102
You will note the line outs DIRECTLY off the DAC chip due to the 2VRMS outputs which do not necessitate an output stage.
__________________
  #38
Old 05-19-2012, 06:50 AM
AK Member
Like I said before, look at the specs!
It REQUIRES 10kohm output (or more) impedance!!! Unless you have headphones that have that value you NEED output buffers.
Plus, the chip itself is a cheap one, capable of THD=-93dB - that is not even 16 bit performance (16 bit equals -96dB). Probably the lack of output active filters leads to that result too.
32bit snake oil.
  #39
Old 05-19-2012, 09:22 PM
pete_mac's Avatar
You'd better get in touch with TI then and correct them. The detailed spec sheet gives full implementation and circuit information and does not specify opamps in any way, shape or form. Either someone at TI has royally stuffed-up, or this DAC chip functions just fine as per TI's own implementation information.
I've also just realised that the JKDAC32 uses this exact DAC chip and it is one of the better DACs that I've heard in this price range, and it has... wait for it... no opamp (or discrete equivalent) output stage. John Kenny (DAC designer) is no fool either. Info and reviews below. John is clearly doing something right here, despite the meagre cost and specs of this DAC chip:
https://sites.google.com/site/hifacemods/home-1/Options
http://www.6moons.com/audioreviews/johnkenny2/1.html
http://www.enjoythemusic.com/magazin...c_shootout.htm
__________________
  #40
Old 05-19-2012, 10:50 PM
AK Member
How about you scroll to page 4 and 25 in their datasheet and read about output impedance?
At THD+N= -93dB (15 bit performance) is nothing spectacular. Regardless what people paid to say differently say. Or they are just taken by the "32 bit" marketing crap.
I see that you have audio-gd Ref 5 (4xPCM1704) as DAC... Can't belive that you can even compare that with the cheap toy from above.
Audiokarma
  #41
Old 05-19-2012, 11:32 PM
budgophille's Avatar
budgophille budgophille is offline
AK Member
I'm in the same boat as the OP, I am also in the market for a DAC. My budget may be a little higher, but not by much. I had considered this: http://www.kingrex.com/productimg.aspx?id=22
But I don't know that it's that much different from the Dragon doodad that was mentioned a couple of pages ago. I heard a Matrix Mini at the fest, and was fairly satisfied with that, but I did want something that would go up to 24/196 through USB, but I do have a 3.5 glass to Toslink coming out of my XPS laptop, and according to the sound settings, I can set my output to that.
I had a couple of questions as well, if you guys don't mind me jumping in here on this thread....
1. I have seen quite a few DAC's with BNC outputs, what's up with that? I'm guessing they might connect to some equipment I can't afford, or would it be more for a commercial application.
2. In looking at the nudies of most of the DAC's here, it just doesn't seem like there's that much to them, compared to say... the MDHT Havana or Paridisea. Is that because they are more in the non-upsampling tube category?
3. Is there are way to search for DAC's on AK? I've tried with "DAC", Dac, "USB+DAC" to no avail. I guess it's a four character min in the Boolean operators?
Thanks so much for any insight on my hodge-podge of questions. Jon
__________________
I added an L for panache.
  #42
Old 05-19-2012, 11:33 PM
pete_mac's Avatar
I understand what you're saying about the specs... but that doesn't change the fact that several manufacturers have designed DACs using this chip, in accordance with the TI spec sheet with NO output stage/opamps, and they perform perfectly well. I haven't heard the musiland DAC but I have heard the JKDAC32 as mentioned earlier and it is very very good for the money with excellent sonic performance. If there was some fundamental issue with implementing the chip in this way, surely there would have been widespread issues by now? A JKDAC32 was sent around on a tour of Australia recently, and nobody had issues running this DAC on a wide variety of systems (from mild to high-end stuff).
That's my beef here... asserting that something is wrong or can't work when there are demonstrated examples of it working just fine, in accordance with TI's own implementation recommendations.
And for the record, I haven't once tried to compare the Musiland DAC to my own DAC... it's irrelevant to the discussion at hand as the PCM1704UKs do require an output stage (which is 100% discrete in this instance, no opamps here).
__________________
  #43
Old 05-19-2012, 11:41 PM
pete_mac's Avatar
Jon, what's your exact budget?
If you can stretch it, the audio-gd NFB3.1/3.2 is an excellent entry-level DAC. If you have any intention of using USB via PC, the 3.2 is the way to go (asynchronous USB). Fully discrete analogue stages. I had the NFB3 (earlier version) and it was fantastic! I did order the DIR9001 receiver board though (24/96 vs 24/192 for the WM8805) as the DIR9001 offered slightly greater resolution and less colouration.
http://www.audio-gd.com/Pro/dac/NFB3-2011/NFB3.1EN.htm
I'm also a big fan of the Schiit Bifrost. Lovely DAC!
__________________
  #44
Old 05-21-2012, 03:24 PM
AK Member
Thanks for the info guys! My budget is roughly $500. I'm selling my Yammy M2 amp, to make room and $ for a DAC. I'll look in to this audio-gd NFB3.1-2, I had initially had my heart set on USB capabilities, but since my laptop (which will be my main source) has the Toslink out, it's not a deal-breaker. I suppose if I ever get around to building a music server, it may be needed then, but I've never been known for over-planning.
I have also heard good things about the Emotiva XDA-1, for an entry level model. Certainly a good price for something with a remote...
__________________
  #45
Old 05-21-2012, 03:35 PM
Andyman's Avatar
Andyman Andyman is offline
Scroungus Stereophilus
Location: 15 miles North of Canada, East of Grumpy. West of Kegger
I'll stick to my guns and second that.
In a market this dynamic, I advocate buying good performance and getting acclimated to the medium and all it's tricks and tips, rather than buying higher performance that may be entry level in a short time for 2-3x the price.
The cutting edge cuts too deep into my wallet
__________________
"The only thing necessary for the triumph of evil is for good men to do nothing."
- Edmund Burke
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Tone Arm Audio
Tuner Heaven
Classic Sound Repair
Take Five Audio
Acoustic Sciences Corporation
Audience AV
Cabledyne
BD Enterprise
BOI Audio Works
Howard Products
Amplifiedparts
Audio Art Cable
RSL Speakers
Siliconray
Salk Sound
Vinyl Magic Record Cleaner
Musical Paradise
Audio Salon
Urban Antigue Radio
Grant Fidelity
Many Moons Audio
Yesterday's Audio
McIntosh Cabinets
Simply Speakers
The Tube Store
DeWick Repairs
AudioClassics
Parts Connexion
Audio Doctor
Vintage Electronics Repair
MCM Electronics
Politicalchat.org
Herbies Audio Lab
Antique Radio Classifieds
Sound Stage Direct
Videokarma.org
FM DX Antenna
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
©Copyright 2002-2012 AudioKarma.org, All rights reserved.
