Greyson
Blind Test - SL-1200Mk2 - AT-LP120
Okay, so technically it's an SL-1210Mk2. Let me explain my reasoning before anyone says this is pointless. Yes, digitizing an analog signal means this won't be a test conducted with labratory precision, however, both signals are being digitized and reproduced on an identical medium, meaning that any difference in sound quality should be evident between two recordings taken with the same equipment.
Build quality is no contest. The LP120 is 80% plastic, has feet that are useless for damping, cheap buttons, a sticky pop-up light, and a stiff cueing lever.
Test specs:
Both turntables are hooked up to my mid-90's Sony GX909ES reciever. The output monitor on the reciever is connected through a stereo RCA to 3.5mm analog cable which goes to the Asus Xonar D2x soundcard in my computer. The source audio is taken at 192khz/24bit resolution and encoded to Uncompressed PCM.
Each turntable used the same Ortofon 2M RED cartridge and SH-4 headshell. Each turntable used the same rubber Technics platter mat. The same copy of each record was played on each turntable. The LP120 is operating in "line" mode, bypassing the internal preamp and using the Phono input on the Sony.
Can you tell which turntable made each of these recordings?
Jazz - Miles Davis - Blue In Green ("Kind of Blue" Parlophone | 33rpm)
Turntable #1 http://dl.dropbox.com/u/1244235/Turntable/1-milesdavis.wav
Turntable #2 http://dl.dropbox.com/u/1244235/Turntable/2-milesdavis.wav
Rock - Radiohead - Just ("The Bends" Capitol Records | 33rpm)
Turntable #1 http://dl.dropbox.com/u/1244235/Turntable/1-radiohead.wav
Turntable #2 http://dl.dropbox.com/u/1244235/Turntable/2-radiohead.wav
Electronic - Thievery Corporation - The Heart's A Lonely Hunter ("The Cosmic Game" Eighteenth Street Lounge Music | 45rpm)
Turntable #1 http://dl.dropbox.com/u/1244235/Turntable/1-thievery.wav
Turntable #2 http://dl.dropbox.com/u/1244235/Turntable/2-thievery.wav
edit: For archival purposes the answers are now here in the first post: http://pastebin.com/embed_js.php?i=Yt64h8vg
