kennedy6949
I am about to recap my Kenwood Basic C2 preamp and while doing some research became curious about swapping out several of the op amps for better performance.
Since this system is about 90% vinyl, I want to start with the phono amp and then the flat amp. If it goes well then the tone amp would be next. The filter amp also has an op amp, but I don't use them at all.
The eq, or phono, amp uses a NJM4560D op amp, and is powered by +/- 19v. The flat amp uses a NJM2041D and also uses 19V. These are both DIP8 with standard pinouts. Because of the high voltage, I was thinking the OPA2604 would make a good match. After doing some research, I am leaning toward the LME49860, due to the fact that it is bipolar, as is the original 4560. It also appears to be fairly stable.
As for the flat amp, I am not as sure, but it looks as the LME49860 should work also?
I've included the schematic from the service manual, if it helps.
If these work out, would it benefit to change the tone amp and headphone amp op amps also?
Thanks.
Thanks.
