Sony TC-K61 cassette deck -- REW/FF needs help
deniss
I got the Sony TC-K61 cassette deck recently, and it plays and sounds fine. All the switches, selectors, and LED level meters work. The one issue with this deck is the REW and FF are reluctant and inconsistent to engage. And when I say reluctant, I mean REW and FF will not function most of the time but will function some of the time.
Upon some investigation, I concluded that while the belts are somewhat tired, they are all functioning. Tape counter works fine both in PLAY mode and in REW/FF mode (when REW/FF actually works). Motors all run as they should and the voltages supplied to those motors are within spec, as per the service manual. The power supply board puts out proper voltages also. No plastic parts appear broken or missing.
So it appears that everything's working normally, except the REW/FF don't engage consistently!
Here's what the service manual has to say about the REW/FF mechanism:
I removed the reel motor, since it's functioning properly, to evaluate the "changing plate" and its idler (see diagram above).
The idler turns with some friction, which is by design as the service manual states. When the reel motor runs the idler, friction from the idler is supposed to drive the plastic plate (called changing plate in the diagram) to swing over either right or left (depending on which direction the idler is turning).
The problem is that this "changing plate" with the idler on it seems to encounter enough friction elsewhere to defeat the friction drive from the idler rotation. Perhaps there's too much friction between the changing plate and its plastic backing. Perhaps there's too much friction between the reel motor shaft which fits through the hole in the changing plate and the changing plate itself. Perhaps backward protrusions of the changing plate rub against the chassis or other plastic parts and don't have sufficient lube where needed.
There is some grease on the reel motor shaft where it fits through the hole in the changing plate. There's also some lube on rear protrusions of the changing plate that make contact to other plastic parts and chassis in the back of the mechanism.
It sounds like I need to remove the old lube and apply some fresh lube and perhaps fresh grease on the reel motor shaft.
Which lube and which grease would you recommend me to use? The ones in there now are amber colored.
Here are front and rear pics of the changing plate mechanism (I circled parts of the changing plate mechanism in red):
In the last image, I circle holes where parts of the changing plate make contact with the chassis or other plastic parts.
Any advice appreciated.
White lithium grease is best. The amber colored stuff is old, dried and dirty grease and should be removed.
Thanks for the advice -- I got white lithium grease today, removed the old amber-colored grease, and applied the white lithium grease to the appropriate contact points of the swing arm assembly and also the break arm (which keeps the swing arm centered unless REW/FF are engaged).
The result -- the tape deck is fixed! REW/FF now work flawlessly and engage instantaneously. Eventually, I'll need to replace the belts on the deck, but right now I'm just enjoying it... And after cleaning the head with ethanol, it sounds terrific. A very worthy tape deck indeed.
Excellent! The thought of these 30-years old machines being restored and enjoyed is one of my favorite pastimes. Enjoy it!!!
Thanks much for posting! I have a TC-K71 that (mis)behaves very similarly. I'll try the lithium grease, too.
It's surprisingly difficult to find White Lithium Grease in local stores. I called a couple local Radio Shacks and they haven't even heard of it (:scratch2:). The only place that had it locally was an auto parts store -- they had a nice little tube from Permatex (USA-made) for 2.99, which is actually cheaper than on Amazon for the same thing.
This is a pretty nice deck to work on -- not too complicated, and the layout is very DIY friendly.
Another superb machine! I have two of these also. In fact, at one time I had the entire 1980 lineup except for the BOTL deck, TC-K22.
Sony cassette spoken here....
[QUOTE = "deniss, post: 5859130, member: 83537"] Es lohnt sich wirklich, das Problem zu beheben: yes:
Ich habe das Druckservice-Handbuch für Sony TC-K61, das ich gescannt und auf HiFiEngine.com hochgeladen habe:
http://www.hifiengine.com/manuals/sony/tc-k61.shtml
Wenn es hier auf AK einen Ort gibt, an den ich Handbücher hochladen kann, lass es mich wissen. [/ QUOTE]
Hallo, leider kann ich das Manual und Servicebuch nicht herunterladen. Ich kann mich nicht auf deiner Seite anmelden. Proxy und VPN habe ich nicht nur einen Router. MfG Riddle
I just fixed the exact same thing last night! I know what needs to be done. Lemme know if you still have this prob or not
