All about Sony STR-V7
Status
Not open for further replies.
Pepa
Well-Known Member
Once upon a time I had a three Sony’s... TOTL...the biggest,the baddest...STR-V7 :D
Here are a few pages of the catalog from the audioidiots website:
It was a great receiver, but it's too late,Sansui,Pioneer,Marantz and others have already taken their piece of the cake :tears:
If you already have one, then you will need these things particularly:
Brochure:
Operating instructions:
Service manual:
Past few months I have big problems with my friend and best man. ..he desperately wants one of my vintage receivers, and I don’t like the idea that any of my Sansui leave apartment. So what to do? I offered him a Sony... He is thrilled :banana:
Since the device is in its original condition,there is a job I got to do...
First, let's take care of all the switches.
comparison of clean and dirty switch
This time I made a test.
All switches have been chemically treated several times and they were in an ultrasonic bath for a few minutes.Take a look at DMM...resistance (between contacts) should be zero!!!
My thoughts are that you can't expect proper operation and good sound with such contacts.
I know that this is a pain in the ass,but the best way is to disassemble each switch and clean it by hand
input board with eq
tape sw and selector are out
same procedure
Most of caps are changed too :yes:
While the switches are on treatment...I didn't forgot the pots....this is a line amp (without sw)
I didn't forgot the pots,but I'm running out of pics :tears:....just a few more,and it will be all for tonight.
transformer weighs 6,5 kg :D
main caps
and main PS
Don't you worry,receiver is live and kickin' (white smoke is still inside) :D
to be continued..
Ah, come on. Thats not only "good". So much time you have to spend for this wonderful unit. I admire your work really!:thmbsp::thmbsp:
...Which date in September exactly?;-)
Oh wow. Nice work you did there. That's invasive to the maximum. I bet the unit sounds a lot better as a result!
How does the Sony STR-V7 compare to your other units, specifically the Sansui's?
That might be a wonderful idea - I have never been in this part of the world:yes:...
Although its not that far away from Germany:scratch2:
Never?...shame on you Peter...I've been in Germany more than 50 times :D
Tnx...yes you are right,sound is much,much better...you would not believe.
If I would have to say in percentages,I would say 50 percent,at least :yes:
I would like to know that too,but any comparison between them is impossible at the moment (lack of free time) and will have to wait.Fair comparison would be G8000,or my G901 which is still in its original state.
I read that many mention muddy bass on that Sony,but what I hear is very fast and clean sound and great stage :smoke:
and the last round before going to sleep...
I noticed one problem, the sound slightly turns down and go up again (like fade in/out) . It happens on a low volume level only...never on mid or high levels. I thought that volume pot is culprit but is not.Reason for that state is relay which is located in one of power amp pcb.
Let's see it
top
bottom view
one ch
other ch with protection
to be continued...
speaker relay...
Here you can see dirt at the fixed contacts of relay
contacts are not burnt...so just a little cleaning is needed
to be continued...
Status
