Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > DIY
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 07-14-2012, 01:52 PM
StevenZ's Avatar
StevenZ StevenZ is offline
Texas or nothin'
Mark Audio Alpair 12P Pensil Build
Hey guys,
Just thought I should start a quick little build log here for my newest speakers. As some of you know, I've picked up a pair of Mark Audio Alpair 12P full range drivers. These are Mark Fenlon's newest top of the line (as well as largest)drivers which use a Japanese paper cone, as well as Japanese suspension parts, non-resonant plastic frame, reversed roll rubber surround, etc. They are made in small batches and are hand assembled in China with Mark Fenlon carefully watching over quality control to make sure that each pair comes out perfect.
On to the build.
I drew up the cabinet in AutoCAD and ported it over to our CNC router. Here is a quick video of the CNC router cutting the parts out. *Volume warning, it may be loud*.
http://www.youtube.com/watch?v=KXe8WVix4zA&feature=plcp
This original enclosures were supposed to be out of Domestic hardwood core plywood but it seemed my machine wasn't calibrated properly as well as the material being under 3/4" so I threw away the entire sheet and started over. This time around I got some true 3/4" MDF and triple checked the machine parameters to make sure everything would be perfect before wasting another sheet. The parts came out absolutely perfect, accurate to .0001".
Moving forward, I had a little time this morning to throw the enclosures together. Here are a few photos of the build. As you can see I opted for window bracing instead of the original "holey" bracing called for in the plans. As of right now they are waiting in the finish room and have a couple coats of sealer already thrown on. Monday they will get an off-white paint sprayed onto them and should be fully mounted by Wednesday. I rounded over the front edges to give it a "softer" look and reduce diffraction.
Also, as you guys can see I added more material to the inside of the cutout due to the flush mounting rebate being so deep, only leaving 1/4" material to screw into. I added 1/2" more which gives 3/4" material to screw to. I did a small round-over on the inside edge of the cut-out but I don't think it's adequate as I believe that the driver will need more room to breathe. Soo.. with the enclosures already sealed up I'll just take a small sanding wheel from a dremel and chamfer the inside edge a bit. Shouldn't be a problem, just a little time consuming.
Anyways, I'm excited that I've made progress on the enclosures and can't wait to listen to them next week. Hope you guys enjoy!
Cheers,
Steven
__________________
The best crossover is no crossover.
  #2
Old 07-14-2012, 01:58 PM
StevenZ's Avatar
Texas or nothin'
Here are a few photos of the drivers. The drivers are sold in pairs with matched parameters. This set is matched at 44hz.
__________________
  #3
Old 07-14-2012, 02:19 PM
Vaughn's Avatar
Vaughn Vaughn is offline
AK Member
I got one more hz than you
  #4
Old 07-14-2012, 03:38 PM
ejfud's Avatar
ejfud ejfud is offline
Audio Pinhead
Great build pictures.
Patiently awaiting your thoughts on this build.
__________________
Gary
i jam econo.
  #5
Old 07-14-2012, 04:06 PM
Vaughn's Avatar
AK Member
+1
I'm trying to decide which direction I'm going to go in for these drivers. Seems like there might be several available soon.
Audiokarma
  #6
Old 07-14-2012, 05:25 PM
StevenZ's Avatar
Texas or nothin'
Thanks guys! I talked to a few people who have already compared the Ken style enclosure and the Pensil and the general consensus is that the Pensil, even standard sized, walks all over the Ken style box. I would have gone with the Super Pensils to gain a bit more bass but the dimensions were killing me. The "Standard" Pensil is more aesthetically pleasing and should be able to blend in well with the room by opening up more placement options.
-Steven
__________________
  #7
Old 07-14-2012, 05:33 PM
Redboy's Avatar
Redboy Redboy is offline
a few good watts
Don't pay me any mind... I'm just here for the show.
__________________
Now Playing: Nate's interim
  #8
Old 07-14-2012, 06:55 PM
ejfud's Avatar
Audio Pinhead
Quote:
-Steven
So what are we talking about as far as bass in the two Pensil designs?
__________________
Gary
i jam econo.
  #9
Old 07-14-2012, 10:57 PM
StevenZ's Avatar
Texas or nothin'
Quote:
Honestly I have no idea. The designers of the Pensil cabinets (Scottmoose & Planet10) absolutely refuse to publish any measured response graphs or even give a general estimated frequency response. As to why they don't is anyones guess. Also, I seem to get in trouble with Planet10 every time I don't use his signature 'holey' bracing for his enclosures and am awaiting a solid response from him as to why he thinks my window bracing will hurt the performance of my build. I'll post his response here if/when he replies.
Steven
__________________
  #10
Old 07-15-2012, 08:05 AM
StevenZ's Avatar
Texas or nothin'
So, Dave says that with my bracing it may disrupt the 1/4 wave TL and adversely affect the bass response, though another fella answered (Bob Brines) and included that he's done the same bracing in many TLs of his own and has had zero adverse affects and no measurable differences in sound. Bob did recommend more bracing, though, but to be honest my bracing is primarily to allow the polyfil to stay in the enclosure without falling and coming thru the port.
If I hear excessive panel resonance I'll add some decoratively cut hardwood panels to the outside to stiffen up the enclosure a bit, though, the reason I used MDF is because of it's natural panel damping properties. In my personal opinion, and experience with many building materials, I favor the acoustic properties and damping of MDF over birch plywood. Though this thread isn't the place to get into such a topic, it's merely a personal preference. I'll keep you guys posted and update the thread with any findings as I move along.
Thanks,
Steven
__________________
Audiokarma
  #11
Old 07-15-2012, 04:38 PM
ejfud's Avatar
Audio Pinhead
I built my Jordan two ways with window bracing. Bob's design is built this way and they sound great.
__________________
Gary
i jam econo.
  #12
Old 07-15-2012, 09:42 PM
Rick Vestal's Avatar
Rick Vestal Rick Vestal is online now
Have a nice day and duck!
That was my first time seeing wood cut with cnc... Are there companies out there that you can provide drawings on paper to them and they provide you with a finished cut set? Being a condo dweller I don't have access to large saws...
__________________
"It's all about placement. The HPM sounds best placed face down. If the room won't allow that placing them in a room you're not in works well." -Tom Brennan
  #13
Old 07-16-2012, 05:38 AM
StevenZ's Avatar
Texas or nothin'
Quote:
Absolutely. Most larger custom cabinet shops should be able to help you out. I can't be sure on how much they will charge, though. It only took me about 10 minutes to draw the program, and another 4 to cut the material. So all in all, 15 minutes from design to finished product.
-Steven
__________________
  #14
Old 07-16-2012, 09:38 AM
scott1019's Avatar
scott1019 scott1019 is offline
AK Member
Looking awesome Steven! Keep up the good work! "The eyes of the Ranger are upon you"
__________________
Music tells your story, seethes your anger, relaxes your worries, celebrates your excitement, embodies your emotions ... from across the years & for multiple time periods & reasons ... even if you can't...
  #15
Old 07-22-2012, 08:13 PM
StevenZ's Avatar
Texas or nothin'
Copied from my other thread "I Love Full Range!"
Well fellas, it's been a while but I finally had some time to get the cabinets sprayed and drivers mounted. Unfortunately my local supply store for polyfill was closed today so the cabinets have zero stuffing in them but my results are pretty damn good so far.
So far, even though I'm in my 1st hour of listening, they're amazing. I have always loved the sound of Mark Audio drivers, and these are no exception. Simply beautiful sound. Well balanced and as good as you can ever want from a full range single driver.
I'm using the "standard" sized pensil cabinet and am hearing some very good low end extension and I'm sure the "super" Pencil enclosure will produce a bit more. For my listening habits and small listening room I feel the standard pencil is perfect. It's aesthetically pleasing and easy to properly place in a small room due to it's small foot print.
All in all i can't wait until they're fully broken in. The manufacturer suggests 100 of soft listening with natural instruments and then gradually increasing the volume. It's sure going to be a long process as I'm already feeling the urge to crank it (and have done so a few times ).
Cheers,
Steven
__________________
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Tone Arm Audio
Tuner Heaven
Classic Sound Repair
Take Five Audio
Acoustic Sciences Corporation
Audience AV
Cabledyne
BD Enterprise
BOI Audio Works
Howard Products
Amplifiedparts
Audio Art Cable
RSL Speakers
Siliconray
Salk Sound
Vinyl Magic Record Cleaner
Musical Paradise
Audio Salon
Urban Antigue Radio
Grant Fidelity
Many Moons Audio
Yesterday's Audio
McIntosh Cabinets
Simply Speakers
The Tube Store
DeWick Repairs
AudioClassics
Parts Connexion
Audio Doctor
Vintage Electronics Repair
MCM Electronics
Politicalchat.org
Herbies Audio Lab
Antique Radio Classifieds
Sound Stage Direct
Videokarma.org
FM DX Antenna
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
©Copyright 2002-2012 AudioKarma.org, All rights reserved.
