I bought a Pioneer SX-626 recently. I'm glad I checked the fuses before powering it up, as someone had done the old aluminium foil trick on them. So I replaced them all with the correct 2A ones, sure enough, they started to blow when powered up.
I traced the problem to the power amp board, since with the power amp fuses removed, the main fuse didn't blow. You can actually pull the pre/power jumper, and use it as a tuner/pre-amp. I wanted to get it going properly, so here goes the rest of the story.
I used the list of capacitors and transistors in this thread to place an order with Mouser. Kind of, I did substitute Nichicion KWs for the caps. I also ordered a replacement main power supply capacitor.
Here is a picture of the amp board on it's way out.
On the workbench, AKA the kitchen table, I was shocked to see ALL the power transistors as dry as a bone, there was no trace of heatsink compound left anywhere.
Here were are with new caps and transistors in place. The original output caps have a 4-pin design with two pins connected together. Since my new caps were only 2-pin, I had to make a link on the bottom of the board (blue wires).
But I wasn't done...
When I put everything back together, the amp still kept blowing a fuse. I researched another thread which mentioned the trimmers could go open circuit. I pulled mine off and tested them, and sure enough, there were a couple of bad ones. I elected to replace all of them, and since I couldn't find anything as large, I made up some little stripboard uprights with Bourns trimmers on, which as luck would have it, I had some 100R and 50K left over from another project.
With these in place, I was now able to set the center voltage and offset as normal. Here are some pictures of it all back together. Notice I had to use a rubber P-clip to hold the new main power supply capacitor in place, it's a lot smaller than the original. The flying white wires used to set the bias had their bare ends trimmed off, and were hot melt glued onto the output caps.
Lee.
Lee.
