Hi,
I hope someone on this forum might be able to help me.
I recenty bought Onkyo T-9990 (same as T-9090II) tuner, but it seem it has some tuning issue/problem.
There are 3 main problems that I discovered so far (…they are all connected together).
The main problem (first) is that the tuner can not "fully tune" into the station's frequency.
Let say I'm pressing UP frequency button..and let say on "100.00 Mhz" is a radio station. When I reach 100.00Mhz, the sound is ok, etc. but the “TUNED INDICATOR LED” (D722) never locks in (…3 LED diodes on the front panel...”<” left, “TUNED”, right “>”).
Only "left diode" (D721) is fully blinking (working) while tuning (UP or DOWN).
"TUNED" LED diode (D722-middle one) only comes on very, very little bit…while the right LED diode (D723) never comes on!
(So basically, just the left side of the S-curve as marked on the attached picture – Fig. 14…but only, kind of, first 1/3 of it).
Since the tuner is not able to properly "LOCK IN" into radio station's broadcast frequency, the sound is always MONO, unless I switch it on manually to STEREO.
And also, consequently…because not properly "locking in" the APR button is not functional (second problem).
Normally, once properly tuned to a station, APR automatically selects best IF settings, HI-Blend ON/OFF, RF mode (LOCAL or DX)…and the stronger signal either on ANT A or ANT B input.
But when pushed, APR always chooses SUPER NARROW mode, HI-BLEND ON and STEREO-OFF. Always, even for a local station with maximum signal!
That is because APR only works once the station frequency is "TUNED or FULLY LOCKED IN"...and in this case, since the middle LED diode is never fully on (LOCKED)…the tuner (or APR circuit) always thinks that the station frequency is not correct...because only "<" LEFT LED diode is ON.
More over, consequently third problem connected to this TUNING issue, is that the "Automatic Tuning" is also not working. It searches/scans indefinitely through the band, from 87.50Mhz to 108.00 and than all over again.
It never stops, because the tuner can never "lock in" into a station.
I don't know what is the reason for this tuning problem but I think it is most probably the age...and some components need replacing. …
I got the service manual and looking at the schematics diagram, I think there are two chips (ICs) that might be problematic.
They are "Tuning Indicator Drive IC" which is LB1450 and "IF System IC" which is LA1235.
Maybe they need replacing...I don't know. Or maybe some capacitors or some trimmers only need readjusting..?!?
Regards,
Regards,
minor comment - I don't know how "digital" the 9990 is, but many digital tuners can't lock into stations unless they are at an odd .1 mhz frequency - i.e. 99.0 mhz won't tune, but 99.1 or 98.9 will due to the way stations are assigned and the controller is prorammed. (however, in Europe it shouldn't make a difference)
