Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > The Klipsch Korner
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 09-07-2012, 08:46 PM
dieselsdad dieselsdad is offline
AK Member
Klipsch kgsw subwoofer
Hey gang. I'm new to this forum and new to the world of Klipsch. I've learned a ton since finding this site yesterday, having spent most of my free time in it. I bought a set of original Heresy's a little while ago and like others decided I needed more bass. I came across a klipsch kgsw subwoofer but I can't find any info on it. I'm guessing that maybe it was part of a kg speaker set at one time? Does anyone know more about this subwoofer? Since hanging out here I've learned that I can mod the Heresy's for better sound by bracing the box and adding seals and whatnot, also going to look at rebuilding the capacitors with some crites stuff. Any help on the kgsw would be appreciated.
  #2
Old 09-08-2012, 10:48 AM
Chipbyrd Chipbyrd is offline
AK Member
I love Klipsch. I use them in my two channel setup and love the horns. (The Crites mods are worth every penny.) Having said that, IMHO, Klipsch subs don't stand up well against the competition. Check out Rythmic F15 or HSU ULS-15.
  #3
Old 09-08-2012, 12:28 PM
moray james's Avatar
moray james moray james is online now
AK Member
Quote:
Diesekdad: welcome to the forum this is a great place. I have a pair of Heresy and a pair of H3. the H3 are fully braced and stiffened with solid oak and stuffed about 85% with high density acoustical ceiling tile fiberglass. The woofer has 3x1/8" SAE rated F-11 acoustical felt over the spider and a 14" on the struts along with a layer of Dynamat on the basket and magnet assembly. The speakers are up on four post stands about 21 inches high. I have two HSU subs and the speakers sound better with the subs off though with a tad less bass weight that way they stage and image better sans subs and they have a more organic quality about them without the subs on. Noe shortage of bass all on their own. I would suggest you go that route first and then see what you think with a sub. I plan on doing the same to the subs and blocking off the vents to make them a sealed box to better match the Heresy. Best regards Moray James.
  #4
Old 09-17-2012, 08:47 PM
LAB3's Avatar
LAB3 LAB3 is offline
AK Member
Nice 1993 Klipsch KG KGSW LE Subwoofer
All original with 2 K1002-K 20H 8" speakers
Very rare LE model with the upgraded K1002-K speakers,
the earlier KGSW model was offered with two K-1004-K 8"
All original black painted walnut cabinet with rubber feet.
Good condition with a few minor edge and corner bumps,
original black factory floor cabinet, never opened up or modified.
Original cones and foams, viewable through dual ported side.
No cone rubbing, no cone wrinkles, no distortion, nice full volume range sound,
No warping, no chunks missing, no separation, minor edge wear only.
No coffee or cigarette stains.
Klipsch Subwoofer
KGSW LE
Specifications
FREQUENCY RESPONSE 34Hz-150Hz(+-)3dB
POWER HANDLING 200 watts maximum continuous, (600 watts peak)
SENSITIVITY 91 / 94dB @ 1watt/1meter
NOMINAL IMPEDANCE 8 ohms / 4 ohms
LOW PASS CROSSOVER 150Hz Fixed
SPEAKERS: Two K-1002-K 8" (20.32cm) Injected Carbon Graphite cones
ENCLOSURE MATERIAL Medium density fiberboard (MDF)
ENCLOSURE TYPE Bandpass
DIMENSIONS 12.25" (31.1cm) x 24.25" (61.6cm) x 15.9" (40.4cm)
WEIGHT 45 lbs. (20.2kg)
FINISH Black
BUILT 1993
From a Epay auction that is at $165.00 right now. I have several Kilpsch Synergy Sub 12" 300/650 watt, BASH amp in them. Klipsch made these for about 8 years(there are still new one's to be had). My first two were used ($400.00 for the pair shiped)ONE works awsome with my stock Heresy II. My 3rd one, Amazon new $249.00 shipped(this one is with the HII in the bedroom system now). In a small room you can get away with a entry level sub. Bigger room purchase a better more powerfull sub. I took Moray's advise and raised my HII so the mid horns were at ear level (like my Cornwalls) and aimed the mid horns at me WOW should have done this 20 odd years ago. Any decent sub with the gain at mid settings will work wonders with a Heresy. I have tried several subs with mine and all worked great in my small rooms. Enjoy the Klipsch and welcome to the forum.
Louis
__________________
Hafler P3000 X2 P1000 DH110 DH330
Revox A-77 MKIV D Nakamichi BX-100
Klipsch Cornwall Heresy II RS3-II C7 Sub 12" X3
Pioneer PL-518X Denon AU-300LC/DL103R
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Hudson Valley Hi Fi
Okki Nokki
Organ Donor Parts
Capacitor World
Parts Connexion
Vintage Home Audio
Take Five Audio
Wargos Electronics
Audience AV
Sonneteer
Simply Speakers
Sound Stage Direct
Howard Products
AudioClassics
FM DX Antenna
The Tube Store
Many Moons Audio
Musical Paradise
Yesterday's Audio
McIntosh Cabinets
DeWick Repairs
BOI Audio Works
Politicalchat.org
Amplifiedparts
Audio Doctor
RSL Speakers
Videokarma.org
MCM Electronics
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
