DublinTrader
Well-Known Member
I posted earlier this month about a pair of Klipsch KG 4 speakers I purchased. Unfortunately all the dust caps were pushed in. I tried everything in my bag of tricks such as tape and using a vacuum and was able to sort out the driver dust caps but couldn't budge the rear firing woofer or the tweeters. I was about to accept that I would be able to do anything and then inspiration struck. I remembered a tool I had bought from Vintage Electronics to replace belts in tape recorders and other belt driven gear. It is long with a very small hook on one end and a small slotted blade on the other. I then used the hooked end to grab the dust cap and pull it out. They didn't come out perfect but I'm happy with the result
The before-Tweeters
The after-Tweeters
The before-woofers
The after-woofers
I am very pleased with the result. I can't even notice the insertion points.
This is the tool:
The before-Tweeters
The after-Tweeters
The before-woofers
The after-woofers
This is the tool:
