Frank Sol
Lunatic Member
If for some reason you are not 100% satisfied with the sound/music from the Ti Mid try this if you can...
*Keep in mind I have external XOs so this is much easier for me*
Put a resistor before the cap/transformer in series with the + line (Bob Carver trick) Try 1.5 - 3.0ohm resistors
Leave the woofer and tweeter as is
Cheap to do... you can use sand resistors for testing. May want to move up in quality if you did this as a permanent mod
If you do try this report back your findings
