little-al
I have two old Fisher branded 12" woofers, one early/mid 1960s the other early 1970s, but appear essentially identical. Both alnico. One was sold to me as an 8 Ohm and the other as 4 Ohm.
With a DVM, one reads about 4.2 Ohm (the advertised 4 Ohm), the other about 5.2 Ohm (the advertised 8 Ohm).
I haven't seen too many speakers advertised as 6 Ohm, although I suppose they do exist.
Based on this measurement, what do you think the actual average impedance is for these?
I'm really looking for a 4 Ohm driver in this case. Usually a DVM reading of a speaker reads a bit low not high, that is for an 8 Ohm speaker is it often a reading of around 6-7 Ohm. But perhaps that isn't always true?
Would either of these be OK for an application where I want a 4 Ohm speaker?
Thanks!
Al
Thanks!
Al
