pingu_turbo
On a constant search...
Hi Guys,
I think I'm going to need some help with this one...
ity:
I must say I’m having a bit of a nightmare this afternoon with the 2230, I was using it again enjoying the sound for the last few times before the recap and the right channel all of a sudden started popping in and out and before I had a chance to turn her off, the channel died. With a little puff of smoke from the right hand side of the cabinet.
So on to the bench, covers off, right hand P750 out and I have some visibly damaged resistors and a load that don’t value properly. I checked the two output transistors H756 & 755 in situ (is this ok to do, or do I have to remove?) they have continuity across e & c but H752 I removed as I had funny values, I have nothing across e&c, dead.
The two output emitters are not spec. R775 & R774
The damage as follows:
R753 incorrect value
R756 incorrect value
R758 incorrect value
R759 incorrect value
R761 incorrect value
R766 measures ok, visible damage
R767 incorrect value
R768 measures ok, visible damage
R769 incorrect value
R771 toasted
R772 measures ok, visible damage
R778 incorrect value
R779 incorrect value
Do you have any suggestions on other components to check, do I have to remove the other transistors to test H755 & 6?
If it is as straight forward as replacing the resistors and transistor, shall I remove the left channel and check the other resistor values, and replace as necessary or do the pair uniform to one another? Obviously I want both channels the same. Or is this a perfect time to pop some good quality components in both sides?
I am an amateur when it comes to repairing amplifiers so any pointers would be gratefully received.
Please see below the P750 as it is now
Many thanks
R771 toasted
Many thanks
