For EL84 fans, the Fisher SA-100 has always been the stuff drool was made of. Big beefy transformers, neat, compact size, and certainly not last or least, the name and look of -- The Fisher. Within the EL84 basic stereo amplifier group, the SA-100 easily takes top dog ranking, besting similar amplifiers from Eico, Dynaco, Pilot, and others -- if only by the size of its transformers alone.
The closest competitor would be the Dynaco offerings due to the quality of their transformers. But these amplifiers were limited by other factors within their design. However, with the addition of my EFB(tm) modification to those products, the modified Dynacos can then handily best the power and distortion levels of a stock SA-100 across the entire audio spectrum, in spite of their overall smaller transformer set. Additionally, the modified Dynacos also run their output tubes at lower quiescent currents than either their original designs -- or that which the SA-100 calls for, which certainly equates to cooler operation, and longer tube and component life. However, the original EFB modification as presented was only applicable to UL designs and certain select pentode designs. It was not appropriate for the Fisher SA-100.
With numerous requests piling up concerning the installation of EFB in a pentode based output stage, I thought it best to detail its implementation into what is arguably the best pentode EL84 design ever produced. Additionally, because it is a fixed bias amplifier to begin with, it offers the ability to showcase the idea of using an EFB supply regulator to provide the "Enhanced" element of EFB, since the fixed bias element has already been provided for us by Fisher. This is a topic I touch on only very lightly in my original article on EFB.
In the SA-100, the EFB supply regulator element then becomes only a portion of the overall EFB II modification, with the remaining portion being the additional EFB elements that control the screens of the pentode output stage.
To develop and prove the theory regarding the EFB II concept, a clone of the SA-100 was constructed, upon which performance was then measured and documented. You can find the details of that project over on the Tube Audio forum here:
http://www.audiokarma.org/forums/showthread.php?t=466229
I am still attempting to post the final schematics of my clone on that thread to finish it out, but have been hindered by the size of the files that each page of the schematic represents. My latest effort to post them has a fellow AKer attempting to shrink them appropriately so that the forum website can accept them for direct posting. If you are following this thread, you might check in on that thread from time to time to see when that effort becomes successful.
In any event, that thread developed enough interest that another fellow AKer sent me his stock, but dormant SA-100, to use in developing a data base of a real SA-100's stock performance for comparative purposes. The adventure of this thread will start with my work from day one on that unit. This initial post serves only to introduce what is to follow, wherein that unit is repaired and brought to stock Fisher specs, performance measurements made and recorded, and then the surgery begins. Along the way, I will document the operation of EFB II, so that others can install it in numerous other settings appropriate for its use if they wish. In the end, this will result in a new article for the Tronola website, documenting all the possible versions of EFB and EFB II (there are four of them), so that any and all interested DIYers can pick and chose the EFB circuits that are best for their projects.
I can tell you this. To date, I've already done the basic repairs to the SA-100, and have it running properly according to its original design. And, I've already developed the data base of its stock performance as well, which marks where I currently am with this adventure. By comparison, if the the results of my EFB II clone are any indication, this is going to be fun!
So much more to follow -- with pics of course.
Dave
Dave
