OK I wont mock about or philosophize. This is a simple tutorial known to work for improving sound quality from cheap generic computer integrated soundcards with onboard DACs. If you dislike it fine then. Don't bother.
If your willing to try it don't worry everything is simple and reversible.
For the ones who think a run of the mill PC/MAC integrated soundcard with onboard DAC cant sound amazing do this to prove yourself wrong
1) Start using foobar2000 as your main player. Download to install the latest version here http://www.foobar2000.org
2) Download and install the foobar2000 plugin called WASAPI here http://www.foobar2000.org/components/view/foo_out_wasapi
3) Go in foobar2000 Preferences > Components > Click Apply on the newly installed WASAPI if you already haven't.
4) Go in foobar2000 Preferences > Playback > Output > Select WASAPI (event) or if your using external DAC, select WASAPI (USB to DAC) or WASAPI (event).
5) In the same window as step 4) set your soundcard latency to the lowest level possible without hearing distortion or your OS and programs acting out.
6) In the same window as step 4) set 24bit as Output format if your using 24bit 192kHz resolution files. Use 16 bit otherwise. Do not exceed to 32 bit, its pointless to upsample, it will only deteriorate sound. Do not use Dithering option unless your using 24bit files.
7) Right click on the volume icon (Windows) and go in Playback Devices > Speakers, right click for > Properties > Advanced tab. Make sure you have checked both Exclusive mode boxes. This will allow WASAPI and foobar2000 to take care of business, not clumsy Windows.
*For MAC owners, manage how to do the same process in your MAC OS, the steps maybe different but the end result is the same. Excellent sound from cheap electronics!
How does it work? Basically WASAPI plugin bypasses the bottleneck - your OS and hands control of data stream to foobar2000 directly to do bit to bit... and stuff :nerd: Read more on the forums here http://www.hydrogenaudio.org/forums/index.php?showtopic=94907.
The WASAPI plugin doesn't work on older OS such as XP, ME etc. For Windows it needs Vista or above. Still you will benefit better sound quality from foobar2000 over other players even without WASAPI.
Enjoy FLAC/ALAC/Hi-Res files to their full potential!!!
If your willing to try it don't worry everything is simple and reversible.For the ones who think a run of the mill PC/MAC integrated soundcard with onboard DAC cant sound amazing do this to prove yourself wrong
