patfont, why did you decide on Chemicon caps for the main filters?
I thought you might have gone with Nichicon KG or Mundorf.
I had originally planned on using the KG's or Mundorfs. I spent very many hours planning what I would do with this 2245. As most of the work had already been done by other AK'ers, for example Catrafter with his phono board suggestions. As I was working on mocking up the Main Filters I do have the KG's in house but was very turned off by the installation aesthetics namely the blobs of solder I see on the wires wrapped around the small grounding rod, and how close that sits to the main filter caps especially the snap in type with the soldered on ring terminals. So I decided to go screw terminals. From the start I wanted this to be a "Really Nice Rebuild." My goals were superior sonics, and nice aesthetics, with components fitting and looking nice. If any one decides they would like to use the Chemi Main Filter caps I do not think they will disappoint you, I have seen them (the same series I used) used in $20,000.00+ amps by Lamm Industries a cutting edge company and others as well. If they are good enough for that I am sure they will do well in a 2245.
I didn't do it on the 2245 I restored, but it wouldn't hurt to regrease that heatsinked tranistor. I'd replace the small transistors and diodes on P800 too. Just for kicks, really.
They will get regreased along with the outputs thanks for the reminder. On to the P/S board are you talking about the relay driver transistors, and which diodes?
Ah I see a replacment relay, did you replace it in the new pic?
I did not, looks like the gentleman I bought it from had it done. It looks pristine and is working perfectly. When I am totally done I may go back in and replace it just so I can say I did.
And what do you use for bypass cap?
I decided on Vishay 730P 2uf.
I wanted this to be a reasonable rebuild that any one could do. I had to limit the cost of the films I was putting in. They had to sound excellent, and have a reasonable cost and fit nicely. (except one exception I made on the Phono and one on the Pre board)
Here are some of the films I auditioned to go in, just so you can get an idea, and none were crazy expensive.
