sKiZo
Hates received: 92644 43.20°N 85.50°W
I've been hearing good things about Windows 8 having some seriously improved native sound handling without having to jump thru a bunch of hoops. The WASAPI engine is completely recoded to eliminate internal conflicts and streaming issues, and is fully integrated, bit perfect, and the next best thing to zero latency. Plug and play without having to resort to ASIO or other such kludges for effortless USB DAC goodness.
One bit of strangeness - if your DAC is 24 bit native, and your source material is 16 bit, the new W8 kernel will build up the data to 24 bit by adding nulls. The DAC will ignore those and read the incoming stream as 16 bit, so ... no harm, no foul.
W8 also has a completely new DirectSound engine with greater precision and fidelity that makes for major improvements in sound quality. It's resampling and anti-aliasing is now virtually perfect also.
I'll stick with XP on my "work" machine, but I'm thinking I may have to pull the trigger on the new OS for my HTPC. That's currently running XP MCE SP3 et all. No complaints - it's stable and sounds nice - but I'm always willing to experiment, especially if W8 is all it's cracked up to be. Only thing I haven't figured out yet ... there's a Media Center edition also, and not sure if you get all sound handling improvements with the standard edition or not. W8 just hit the market yesterday, so I guess we got time to figure that one out. <G>
