Hi,
A friend recently acquired an AU517 and asked me to check the unit over and do a recap/clean etc, and I thought I’d share the work that was done. And as the title suggests, there was a little hiccup in the work that will be revealed towards the end.
The work to be done was as follows –
Full clean, replace all electrolytic caps (Panasonic FC and Nichicon HE) except the main filter caps, replace all fuse resistors, replace the VD1212 diodes (2X1N4148) and the Bias pots with 10 turn versions.
The unit as received
A quick operational check was done (the owner advised that the unit was working) and all appeared fine, it came out of protection, bias and offset checked OK, and a quick listen showed it worked OK (or at least appeared to…. more about that later)
First off were the driver boards
