DougMac
I just updated my DIY RCM. I was at the Salvation Army and found an old Pioneer equipment rack. I has a lift top for a turntable and I decided I could re-purpose it using parts from my original RCM. The old one works fine, but was mounted under and equipment rack and I had to sit on a stool to use.
Here are some photos:
Opened:
The Shop Vac:
The turntable motor is an ice cream churn motor from GW:
Here is the bottom of the turntable platter, taken from a free torn up cheap Sony TT. I epoxied the lid of the ice cream churn to the bottom to connect to the motor:
Here is the deck with the VPI suction arm. I used black caulk to seal the open joints of the cab to prevent water reaching the MDF:
Here's the simple connection from the vacuum hose to the VPI assembly:
Here's cleaning in action. I spray the record with cleaner, then remove with cotton makup pads:
Here's how much gunk that came off this GW record:
I then spray again with cleaner and spread with a paint pad:
I finally spray with distilled water, that gets vacuumed. The motor runs CCW, you can see just beyond the wand where the record is dry. I normally cover the label with a DIY cover, but didn't here:
To recap, here's my costs:
Pioneer Cabinet from SA: $20.00
Shop Vac Wet/Dry Vac, new: $30.00
VPI Wand Assembly, new: $79.00
Ice Cream Churn, GW: $5.00
Lights, new: $16.00
Custom Tubes from bulk, set of 40: $20.00
Turntable platter: Free
Various hardware: $15.00
Opened:
The Shop Vac:
Lights, new: $16.00
