MAC 4100 Recap
CohibaJoe
AK Subscriber
Just got in the 4100. Looking over the thread from "Whaleman" and JKent.
The Big Caps are not around. I have contacted McIntosh service to see if they have any.
I have found one from Mouser. $34.51
http://www.mouser.com/ProductDetail...zne50dcY7NfdemaAFTMCEjPhxv2P%2bnpOomNv8y5Iw==
Brand: Nichicon
Capacitance: 0.015 Farad
Tolerance: 20 %
Voltage Rating: 100 Volts
Operating Temperature Range: - 40 C to + 85 C
Series: LNR
Diameter: 51 mm
Length: 80 mm
Lead Spacing: 22 mm (0.875 in)
Product: Aluminum Electrolytic Capacitors
Capacitance - uF: 15000 uF
Leakage Current: 3.67 mAmps
Ripple Current: 6 Amps
Termination Style: Screw
Any issues about using a 15,000uf ?
I have my Parts list ready to order...Will wait for any comments on these caps.
Some Pics...Unit is Mint...1 owner..CL buy $550
WoodSides are nice. I contacted mcintoshcabinets.com and they do not make a upgraded cabinet..:tears:
Surprise they do not...
I have a area Cabinet Maker by me...Going to stop by in the AM to see on getting a Nice Custom Cabinet made.
Another Cap question.....0.22uf 400v....
OK to replace with Reliable Capacitor MultiCap PPFX .22uf OR 1uf ?
The last picture...Who is under the covers?
Slipping a piece of tubing over a pigtail fuse was a common practice in that era.
The use of pigtail fuses also promoted the use of S clips and other contrivances so that piggybacking a standard fuse over the blown pigtail could be accomplished.
Brand: Nichicon
Tolerance: 20 %
Series: LNR
Diameter: 51 mm
Length: 80 mm
Need to order soon...Not many left....
Any issues on using the 15,000uf?
Maybe I missed it, but what is the original value?
12,000uf 60v
I checked out a few threads...Did not see any issues on use 15,000UF 100v
Just got a call back from Gail (Mac)...$60 a piece 12,000uf 60v..I also have ordered the 15,000uf 100v from Mouser...Good to have spares...But I am going to use the 15,000uf 1st. I have also placed a order with Mouser and Handmade for the other caps.
Till next week...
Should be ok with 15000 µf. The usual value quoted here in the Mc forum is "higher up to + 50%.
Murray
Murray
I searched and 12,000uf 60v Mac Service has these..$60 each. I ordered 2.
I still orderd the 15,000uf 100v...Seems this Cap/Lug size in the 4100 are tuff to get. Who knows how many Mac has in stock and not sure how long Nichicon will be making the 15000uf 100v.
I also order 2 Blue LED lamps (#1847) from radiolabworks...I can then remove the Orange Gel paper.
All the Parts are in and the BLue LED's.
Also got the Mac parts...VISHAY SPRAGUE Main Caps and Nichicon NR (Mouser).
I am going to replace the Main Caps Last....I also got in MUNDORF M-Lytic AG 15000uF / 63VDC...I am going to use the MUNDORF 1st and see how this sounds.
I will start Friday or Sat....Pics will be posted.
Contrivances - now, that's a GREAT word! :thmbsp:
OK...Started and Pre-Amp done...working on Amp.
The .15ohm 5watt wirerounds will be replaced with Mills.
Working on the Auto-On PC Board.
The Speaker Relay that is in the 4100 is "solder type". Looking at mine..One contact has a Pit Mark in the middle. Sanding this down on this relay is not going to work. Will need to order a New one.
Now...The one that is listed on the "Mac 4100 Under the Knife...Q's" lists 653-LY2-DC48. This is a Lug type and the Mac uses a PC Solder Mount(round).
Now...Seems Mac was cutting corners on the RCA jacks. As you can see Cheap Metal as they bend very easy. Going to replace with some Nice Gold ones.
Now there is another Relay next to the Power Supply Board...
78RCSX-11 24VDC Magnecraft
Has anyone replaced this? Replacement Part #..:scratch2:
The NTE relay is installed. I would BUY these as a Drop In Replacement.
Looks like 653-LY2-DC48 will work...Still looking into this.
Bump...
Omron LY2-DC48 is what I have in my notes. Which is pretty much what you have.
Murray
Thanks...Both relays in the 4100 seems to have the same rating..Just the Auto-On PC Board uses a Solder Mount: http://www.mouser.com/ProductDetail...%2b9WriXe0UA/uaV06gy4rSrnz3ljWdeeK3NkWl2ooQ==
Newark and MCM has these to.
I just got a Email from Magnecraft / Schneider Electric....The replacement part for 78RCSX-11 is 782XBXC-24D
Auto-On : R14-11D10-24P
Speaker: 782XBXC-24D
Completed Volume, Tone and AM boards...
Powered On...and :music:..only thing is FM stereo not coming in well.
FM for tomorrow.
I will need to get a Tuner Alignment..Mac Local Service shop by me.
Need to put a order in for the Speaker Relay.
The Magnecraft / Schneider Electric replacement is 15A as to the one Skippy ps used 10A...Old one is working...but why not put a fresh one in.
So...Can the 10A be used..:scratch2:
