Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Speakers
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 11-14-2012, 09:23 AM
CrimsonGlory's Avatar
CrimsonGlory CrimsonGlory is offline
AK Member
Sansui SP-5500X Speakers
Bought a pair of these from a pawn shop a little ways back. They were the only speakers the shop had that featured the vintage lattice grill look, and when I saw what they were I didn't have the heart to leave them there.
The condition of the speakers is quite impressive. The lattice looks flawless and I haven't found a single hole in the fabric. Obviously these are going to require some attention on the inside, but besides a recap, what would I benefit from addressing?
Also, what's the safest way to pop that small dust cover back out?
__________________
A man chooses; a slave obeys.
  #2
Old 11-14-2012, 01:09 PM
Dave1027's Avatar
Dave1027 Dave1027 is offline
AK Member
Use a vacuum cleaner hose to suck the dent out.
__________________
BIC DV62si bookshelf speaker Mod
  #3
Old 11-14-2012, 02:42 PM
Copa1934's Avatar
Copa1934 Copa1934 is offline
My ears are bleeding
Quote:
Second the vacuum. If it has adjustments for suction dial it down some to start and brace the cone slightly. If you don't you CAN do damage, including getting the base of the VC propped onto the pole piece (not too likely, but I have personally done this).
Look forward to more posts. I have a set of 3500's that I hope to someday work on. Presently they sound pretty good, but I'm hoping will improve with a recap.
__________________
RS-1080, SX-680, 9090DB, STA-2500, STA-860, RX-V795
RS 40-4024a, 5b, 7b, Min-7, LX-5II, JBL L3, L88, HPM-40 (2nd Gen), Infinity 4000, Allison CD7, Advent1, V.A. Haydn (first Gen)
Sony DVP NS755V, Technics SL-1700, Sony WEGA DLP 60"
  #4
Old 11-14-2012, 04:16 PM
just dave's Avatar
just dave just dave is offline
vintage rules!
Obviously these are vintage equipment and are going to require some attention on the inside, but besides a recap, what would I benefit from addressing?
[/QUOTE]
Probably a bigger cabinet. If the vacuum trick doesn't work,bend a pin at a 90 deg.angle and poke it into the dust cap and pull it out.
__________________
Yes,she's my wife and she cooks too!
  #5
Old 11-14-2012, 04:38 PM
blhagstrom's Avatar
blhagstrom blhagstrom is online now
Mad Scientist, fixer.
Quote:
Probably a bigger cabinet. If the vacuum trick doesn't work,bend a pin at a 90 deg.angle and poke it into the dust cap and pull it out.[/QUOTE]
Oooo, hold the pin until all else fails.
A piece of duct tape rubbed in the dent and pulled quickly from both ends works great!
__________________
Favorite Gear: Everything I can get my hands on.
(Gawd knows I have, do and will waste a lot more money in many other ways.)
Favorite Quote: "The difference between genius and stupidity is that genius has its limits"
Audiokarma
  #6
Old 11-14-2012, 04:47 PM
AK Member
Thanks for the advice on the dust cap. I'd really like to avoid perforating it to remove that dent if I can help it, so I'll try with a vacuum and keep my fingers crossed.
At the same time, I'm taking a few moments to read into some of the other AK threads regarding the 5500X, and John L seemed to make a pretty convincing case for replacing the veneer. Truth be told about two minutes after I took those pictures I moved them into my room, and while I was setting one of them down my hand brushed against the bottom corner of one of the cabinets and I accidentally peeled up some of the veneer.
Also, where might I get technical specifications for this particular pair of speakers? I didn't get particularly far with a Google search.
__________________
  #7
Old 11-14-2012, 04:52 PM
Frank Sol's Avatar
Frank Sol Frank Sol is offline
AK Member
use a damp (water) q-tip to wet the cap slightly before using vac
btw- I recapped a pair of these for a friend , he still enjoys them
http://www.audiokarma.org/forums/sho...d.php?t=308462
__________________
Whatever...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
