audiodon
Addicted Member
Hi,
I'm in the final throes of finishing the restoration of my beloved early style Fisher X-1000.
I'd wanted to put it in my office system again. It looks ready.
While this is a Fisher issue, I'd like to ask the help of the larger tube community.
I had some weak output tubes and was doing some tube substitutions and might have short-cycled the unit while swapping tubes around. It is a solid-state rectified unit and I don't know that doing that created my problem.
Symptoms:
Now, with good strong tubes all around, and with all voltages within 5% of what they should be, when I turn it up on the variac and get near or over 400 volts on B+ (should be 412), sometimes I get an oscillation in the power supply that stops me from reading the DC values of the power supply caps and pulls the woofers in and out at what I think is some division of 60 cycles, like maybe 7.5 cps, not sure on that frequency though.
What I've tried:
1. I thought it might be the first can cap, which gets warm. These all were changed and all have 1989 stamps on them, making them 23 years since date of manufacture. So, I replaced the first one, which according to the schematic is
C57B@60uf525V and C57A@30uf@525V. I also modified the values of R111 and R104 from 750 ohms to 660 ohms @ 5 watts. I wanted the value one step down from B+ to be a little closer to the B+ value for the EL-34 output tubes.
No change.
2. The diode bridge terminating at CR4 and CR6 has wondercaps across the diodes. Pulled them. No change.
3. When it does go into this pulsing or oscillation mode, if I pull the variac down to about 110 volts, it goes away and I see a steady DC voltage again.
When not pulsing, oscillating, motorboating, whatever, All voltages are within 5% of where they should be. Most are within about 1%.
I've included a photo of underneath the chassis. As you can see, the restoration has been quite extensive.
The tubes are strong and hold bias and are AC and DC balanced to spec.
A few final points.
1. I see that there's no schematic for this in digital docs. I'll have to remedy that, but it'll have to wait.
2. I don't want to grasp at straws anymore. There's got to be a method to get to this.
3. Negative bias is rock steady as are filament voltages.
4. I'm not getting a good solid AC reading across the middle of the power supply diode bridge. It goes to the red and red/yellow leads of the power supply. I can get measureable AC and DC, which I find confusing.
5. One more thing, the two death caps, C68 and C69 are original. They're really tucked away in there and are hard to access. Also, i have CL-80 thermisters on each black lead of the power supply to pull the voltage down a bit at the power tranny.
Symptoms:
What I've tried:
No change.
A few final points.
