I'm working my way through the repair of an SX980. With the help of Markthefixer, I corrected the power supply voltages. I also recapped the protection and amp boards. The next step was to reconnect everything. When I got the diode stv4h, I thought it would be a good idea to test it before soldering it into the board. Actually, I was thinking of this step as kind of a formality, but then my meter returned "OL" in both directions, for both diodes. Reading the threads on STV-4H here, I got the impression it was a pretty hardy part -- I didn't find any posts where both diodes were simultaneously dead. Hmm. I unscrewed each diode and removed the insulation from the leads. The leads look unbroken but are pretty badly blackened -- I wonder if this is normal. I scraped them with a razor blade to get a good surface for the meter to contact. Still OL, both ways. Thinking my meter might be bad, I used it to test a new zener diode -- that one gave me the expected voltage. the low battery indicator is not on.
I guess my main question for the gurus on this forum is: what should I do next? I still wonder whether my tests are valid, and if they are, what could have caused both of these parts to fail. Relatively recently, this was a working amp. Sadly, the original part seems to be unobtainable. I read some discussion about substitution, but didn't find anything definitive. Someone also mentioned buying lesser, broken "parts" amps on ebay and extracting the part. I would go to that length, if necessary, but would like to avoid it.
I'm at a standstill here. Any help or advice would be greatly appreciated.
