SControl Amp (AWG-045)
AWG-045: C15: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C16: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C17: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C18: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C25: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C26: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C27: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C28: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C31: 100uF 16v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWG-045: C32: 100uF 16v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWG-045: C33: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C34: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C41: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C42: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C43: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C44: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C47: 100uF 16v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWG-045: C48: 100uF 16v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWG-045: C49: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C50: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C51: 100uF 35v CEA: 647-UPW1V101MPD 100uF 35v
AWG-045: C52: 100uF 35v CEA: 647-UPW1V101MPD 100uF 35v
AWG-045: C53: 100uF 35v CEA: 647-UPW1V101MPD 100uF 35v
AWG-045: C54: 100uF 35v CEA: 647-UPW1V101MPD 100uF 35v
Power Amp (AWH-052), times 2, as there are two power amp boards, one for each channel.
AWH-052: C4: 22uF 50v CEA: 647-UKL1H220MEDANA 22uF 50v
AWH-052: C5: 470uF 6.8v CEA: 647-UPW1A471MPD 470uF 10v
AWH-052: C15: 1uF 50v CEANL: 667-ECQ-V1H105JL5 1uF 50v or 667-ECQ-V1J105JM 1uF 63v
Switch Assembly (AWS-109) which also covers the protection and power supply.
AWS-109: C7: .68uF 35v CSZA: 667-ECQ-V1H684JL .68uF 50v
AWS-109: C8: .68uF 35v CSZA: 667-ECQ-V1H684JL .68uF 50v
AWS-109: C9: .22uF 10v CSSA: 667-ECQ-V1H224JL2 .22uF 50v
AWS-109: C10: .22uF 10v CSSA: 667-ECQ-V1H224JL2 .22uF 50v
AWS-109: C11: 330uF 6.8v CEA: 647-UPW1A331MPD 330uF 10v
AWS-109: C12: 330uF 6.8v CEA: 647-UPW1A331MPD 330uF 10v
AWS-109: C13: 100uF 16v CEA: 647-UPW1V101MPD 100uF 35v
AWS-109: C14: 2.2uF 50v Unknown: 647-UPW1H2R2MDD 2.2uF 50v
AWS-109: C19: 330uF 80v CEA: 647-UPW2A331MHD 330uF 100v or 647-UHE2A331MHD 330uF 100v
AWS-109: C20: 330uF 80v CEA: 647-UPW2A331MHD 330uF 100v or 647-UHE2A331MHD 330uF 100v
AWS-109: C21: 220uF 63v CEA: 647-UPW1J221MPD6 220uF 63v
AWS-109: C22: 220uF 63v CEA: 647-UPW1J221MPD6 220uF 63v
AWS-109: C25: 47uF 16v CEA: 647-UPW1V470MED 47uF 35v
AWS-109: C26: 47uF 16v CEA: 647-UPW1V470MED 47uF 35v
AWS-109: C29: 47uF 35v CEA: 647-UPW1V470MED 47uF 35v
AWS-109: C30: 47uF 35v CEA: 647-UPW1V470MED 47uF 35v
AWS-109: C34: 3.3uF 50v CEA: 647-UPW1H3R3MDD 3.3uF 50v
AWS-109: C35: 3.3uF 50v CEA: 647-UPW1H3R3MDD 3.3uF 50v
Equalizer Amp (AWF-024)
AWF-024: C1: 1uF 50v CEANL: 667-ECQ-V1H105JL5 1uF 50v or 667-ECQ-V1J105JM 1uF 63v
AWF-024: C2: 1uF 50v CEANL: 667-ECQ-V1H105JL5 1uF 50v or 667-ECQ-V1J105JM 1uF 63v
AWF-024: C9: 470uF 6.8v CEA: 647-UPW1A471MPD 470uF 10v
AWF-024: C10: 470uF 6.8v CEA: 647-UPW1A471MPD 470uF 10v
AWF-024: C17: 3.3uF 50v CEA: 647-UPW1H3R3MDD 3.3uF 50v
AWF-024: C18: 3.3uF 50v CEA: 647-UPW1H3R3MDD 3.3uF 50v
AWF-024: C21: 4.7uF 25v Bipolar: 647-UEP1V4R7MDD 4.7uF 35v
AWF-024: C22: 4.7uF 25v Bipolar: 647-UEP1V4R7MDD 4.7uF 35v
AWF-024: C31: 47uF 35v CEA: 647-UPW1V470MED 47uF 35v
AWF-024: C32: 47uF 35v CEA: 647-UPW1V470MED 47uF 35v
AWF-024: C35: 47uF 35v CEA: 647-UPW1V470MED 47uF 35v
BOM List:
647-UKL1H4R7KDDANA | 16
647-UKL1E101KPDANA | 4
647-UPW1V101MPD | 5
647-UKL1H220MEDANA | 2
647-UPW1A471MPD | 4
667-ECQ-V1H105JL5 | 4
667-ECQ-V1H684JL | 2
667-ECQ-V1H224JL2 | 2
647-UPW1A331MPD | 2
647-UPW1H2R2MDD | 1
647-UHE2A331MHD | 2
647-UPW1J221MPD6 | 2
647-UPW1V470MED | 7
647-UPW1H3R3MDD | 4
647-UEP1V4R7MDD | 2
I substituted one UKL (AWH-052: C4: 22uf 50v) for an unavailable UPW.
But this list HAS been posted before courtesy of Matt_sd and Kingbubba.
You can tell because they condensed the BOM list instead of it having one component number repeated multiple times...
S
sa-9500II caps same as sa-8500II?
sa-8500ii cap list plus idle current trim pots
amplifier board listed twice because two boards, 1 per channel. 47 components 45 caps, 2 trim pots
this IS NOT FINISHED!!!!
There are many 2sa725 and other problematic transistors in the parts list that if recapping, really should be replaced.
<snip>
Thanks Mark , really
Basic question : When saying "Full Restoration" - Does it mean changing
only capacitors? what about transistors? didoes? and other parts there.. (relays etc..)?
I ask cause i see only capacitors in the list.? am i wrong?
I HATE being right.This is NOT the only thing I had to do today, yesterday and tomorrow. I gave it as much time as I could.
I was AFRAID you would do THIS....I HATE being right.
WHAT'S THE RUSH???????????????
please hold off on placing the order until I can get the transistors and other components into the list, unless you like the costs of double shipping, no less the risks of the work itself.
The transistor (and other parts) replacements are best done at the same time as the recap, because there is always the risk of damage when opening the unit up and freeing the boards from their mounts to work on them.
I DO NOT HAVE THE EXTRA TIME TODAY TO FINISH THE LIST.
Mark Hi...
I Must note down that in my SA 8500ii (HG version - 220/240V) :
AWG 044E - is the EQ. Amp.
AWF 023C - Control Amp.
To the rest , i will come later on...
