pingu_turbo
On a constant search...
I know some of you will well know how to relamp a marantz, but I thought I'd help some that don't. I have included some small tips that may be of some use. Please don't get too bored!
Well this evening I thought I'd better put the face back onto my somewhat bleak and blank looking 2215B. This involved re lamping the old girl to shine some life back into her. I was lucky enough to get the proper lamp kit from a seller on a well known auction site for some reasonable money. It is always worth searching for the correct kit to avoid possible electrical damage and a meltdown of the plastic parts.:yes:
I will start by saying that the 2215B is by far the easiest 22xx receiver I have ever had the pleasure of re lamping.
So without further a do I shall begin.
This is the before shot,
Like I said lifeless looking.
ity:
So I began by making the receiver is turned off & unplugged from the power and taking out the four screws, two on either side.
I find it easiest, once the 4x screws removed to put my thumbs on top of the cover and pull the sides apart using my fingers and carefully lifting the cover off straight up. Was difficult to do using one hand and pressing the camera, but I think this shows the idea.
Set the cover to one side away from the work area so as not to damage it. Once the cover is off you should have something that looks exactly like this.
This is the contents of the kit I bought, the blue leaded lamp is for the tuning needle, the white leaded for the red 'stereo' lamp and the fuse lamps are for the tuning dial and the signal meter.
Ill start with the tuning dial lamps, Loosen the two screws on top of the white plastic mount. These screws are on slots so full removal is not required, however undo them enough so that the washer is not in the way for re-installation. Lean the mount/bracket back to gain access to all the fuse lamps, be very careful of that dial string, the metal on top of the bracket is sharp.
I have a plastic flat small mixing spatula I use to pry out the lamps, but I would have thought a lolly stick would be as effective. I twisted this to pop one end of the lamp out. I deliberately avoided using a flat bladed screwdriver so I didn't brake the lamp and get glass in the receiver.
Install & test, keeping fingers away from the internals, the results could be shocking!
Turn off and unplug the receiver before carrying on work. Reinstall the lamp holder, take care when doing the screws. Make sure they aren't too tight, the plastic is old and brittle.
So next I tackled the tuning needle lamp as was in this area. Move the tuning needle to the middle of the dial to gain as much slack as possible. Then lift the needle out buy twisting the housing as if it were hinged on the rear (string end), and it comes free quite easily.
Next be very careful with a small flat bladed screwdriver to
a/ not brake the housing and
b/ not to stab your fingers
Tease the screwdriver underneath the barb clip and it should un-clip very easily.
Lift off the cover and pry out the metal bulb holder, I found it easier to do this by putting the housing back onto the slider track and attacking it from behind (no comments please) where the small dob of glue is, some have more glue than others but mine had hardly any.
