I looked at my Fisher schematic and, honestly, schematics never speak to me. I just looked at the enclosed SAMS and that makes more sense than the official Fisher schematic.
Then I looked at the schematic for the power supply to my Fisher X-1000, which seems to use a diode bridge to do what these two rectifiers are doing.
Fisher X-1000 diode bridge:
Fisher SA-300 rectifiers according to SAMS:
I think there's been a lot of useful feedback and comments.
Battradio's comment about do we still want it to be an SA-300-B?
For these, yes. At least for me, if I could find a choke that could replace those two 15 ohm resistors, that bolts under the chassis, I'd try it, but I also doubt it.
This amp was made to sit in the back of a console. The official Fisher schematic is part of a Fisher President VIII service manual.
There seem to be a lot of big power resistors in this amp though.
Recently there was an SA-300 on BT that was beat. If I knew my chops better, then the answer to Battradio would be no and I'd hunt for a chassis that could support a redesign and include a respectable choke.
To Gadget's comment about does each rectifier do one half, I don't have the bench free at the moment to look and test with a scope, but I'm guessing yes. Why else would they each go to a tap off the primary, with one using pin 2 to go to the tap and one using pin 8 to go to the tap?
To Jay, did you find any benefit from using one cap to each rectifier? If each is doing a half wave thing, what benefit would splitting the cap up offer? I can see why you've never gotten a straight answer though. Could it be that in 1958/9 they didn't have beefy enough SS diodes so they used rectifiers in a diode bridge, but they did have beefy enough ones in '61 when the Fisher X-1000 was designed?
Interestingly enough, the Fisher schematic offers that C33 for bias and C34 (SAMS schematic C6 for bias and C3 for 290V source, are 10uf 350V caps. I can see beefing that up.
Ah, I'm going to have to sleep on it.
