Rob41
Don't stop believin'
Okay, so I'm finally getting around to repairing and restoring my SAE 2600. It's been a while and may take a bit to complete depending on when I have to ship out again. This amp has had a very hard life on the road, has undergone previous repairs and looks as though it was stored in a garage for many years. Unfortunately I don't have the money to have it professionally restored, but in spite of my lack of experience I think I will be able to do it justice. I do have basic soldering and schematic reading skills but this will still be a challenging endeavor for me.
This will be my first full on repair and restoration of any audio gear so please be patient with me. My background is as a Merchant Marine Engineer and while I do a lot of electrical work aboard ships, my electronics knowledge however is limited but I think I will be able to manage with a bit of help. Please correct me when I use incorrect terminology etc.
I have just ordered the schematics from Stereo Manuals.com so I can't provide those yet. I won't be using ultra high end caps but will be using high quality caps from Nichicon, Elna, or Panasonic. I will try to stay within the same series on each set of boards.
I have done some preliminary testing of the input(?) and driver boards. On both left channel boards all of the to-3 transistors have been replaced with FET transistors. All of the transistors on all four boards tested good. I have not yet tested the output transistors. I've found two resistors that need replacing and another that although tests fine, appears badly burned. There are a couple damaged traces that look like I will need to solder in a jumper as a replacement.
After repairing and recapping the input(?) and driver boards I'll move onto the relay/protection, main board, meter, and lighting boards as well as checking the output transistors.
I do have several nooby questions I'll post after the pictures. I hope you don't mind. :worried:
Left driver board:
The 62Ω 1w resistor is shot and burned so badly that the boards fiberglass weave is exposed on both sides of the board. The trace underneath is damaged to the point I'll need to solder a jumper in it's place.
This leads me to my first set of questions.
1. Are the orange colored resistors like the one pointed out in the picture flame resistant or otherwise a special kind of resistor?
2. On the right driver board, one of the orange resistors has been replaced with a carbon resistor but I can see that it got so hot that it too has exposed the boards fiberglass weave. Should the carbon resistor be replace with the orange original type?
Left input(?)board:
I believe the grey resistors are called precision resistors? Anyway, of the two circled in the photo, they are both supposed to be 750Ω 5w. The one on the left measures 802Ω and the one on the right measures 734Ω.
Round two of the questions.
3. Is this difference significant enough that I should replace the resistors to achieve closer to the specified 750Ω?
4. I'm I incorrect for testing resistors in circuit?
5. Both of the left boards have had their to-3 transistors replaced with FET transistors, is it acceptable to keep the to-3's in place on the right boards or should they be changed for the appropriate FET replacements to match the FET's on the left boards?
6. There are two pots on each driver board. Are they something I should look into replacing or are they not likely to be bad.
7. All I can read from some very poor schematics is that the rectifiers are rated at 25A. I have some new 50A 1000V rectifiers I could use. Is it critical the ratings for these be exact or will my over rated bridge rectifiers work fine?
I know other issues exist beyond these boards and will deal with them once these boards are up to snuff. If anyone thinks improvements can be made with regard to parts materials/types please feel free to let me know. I am certainly open to making any improvements possible. This amp is really "the one" for me. It is the amp I have wanted since I was in my teens and anything I can do to make it shine I will. Any help or input will be greatly appreciated.
edit:
I just placed an order from Mouser and got all Nichicon FG caps for the boards. I also ordered several resistors but I'm not sure if the types of resistors I ordered are correct. The resistors are pretty cheap so if I need to I'll order the specialized resistors.
Left driver board:
Left input(?)board:
edit:
