Dear coachers, After I have studied all the skills and information from Mr. ecluser’s thread carefully: http://www.audiokarma.org/forums/archive/index.php/t-272813.html. I know how to adjustment the BIAS between Power Transistor finally, Thanks Mr. ecluser very much!!! I know more on my favour. I like 1090 warm and power voice very much! Everything of Right channel always in good. But I have still some troubles on My Marantz Model 1090 repair:
1. Major problem is Q723(NEC B618, Power Transistor, left channel) in main amp always burn after I changed it by 2nd hand B618.
Now the third has broken.
Before burned:
1) Test the B618 I would be used, It’s good at 216 Hfe.
2) Solder it to board and install heatsink correctly.
3) Inspect all 4 power transistor on main board, They are good .
4) Inspect the speaker terminals, Good, no shorted.
4) Power on firstly in fear and trembling, No fuse burn and other abnormity.
5) I adjust R771 let the voltage drop to 6mv on 0.47 Ohms (R763). I heard music for approximately 10 minutes then Power off—— I am ready to finetune after a while as Mr. Eclusters experience, I keep the test clip on the resister.
6) But power on again, the Voltage always in 1 mv?! I feel so strange, and inspecting the power transter, Oho! Q723 C-E shorted like before!?
Who could help me?! I am so confused the root cause: B618’s quality? Effect by Other around part ? I inspct them by digital Multi Meter, they are all good.
:tears:
Before burned:
:tears:
