madtech
Well-Known Member
I have two NAD 216 THX power amplifiers that I would like to use, each in bridge mode, to drive a pair of AR9s.
The specs are:
Bridged (Monophonic) Mode
Continuous Average Power Output into 8ohms 400W (26dBW)
(Minimum power per channel, 20Hz-20kHz,both channels driven, with no more than rated distortion)
IHF dynamic headroom at 8ohms +1.5dB
IHF dynamic power 8 560W (27.5dBW)
(maximum short term power per channel) 4 800W (29dBW)
From the owners manual:
"Note: in the bridge mode the loudspeakers impedance is effectively halved as "seen" by the amplifier. An 8 ohm load looks like 4 ohms, a 4 ohm load looks like 2 ohms" etc, and
"For best results the bridging mode should be used with a single 4 ohm or 8 ohm speaker in each channel."
So it looks like each AR9 will present a 2 ohm load to the NAD 216s but there are no listed specs for 2 ohm loads. Should I be concerned about smoking something or go with the second quote and not worry about it.
The specs are:
