Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Tube Audio
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 01-29-2013, 06:05 AM
KenP's Avatar
KenP KenP is offline
AK Member
Xiang sheng 728a schematic
I've gone through every scrap of info I could find, including the one here that shows a schematic but came up empty. The schematic that's shown here is really tiny and if you enlarge it can't see any info. Does someone have a better copy or perhaps a full copy showing layout on the pcb.
Bought this thing used with a hum issue and it really sounds nasty and dirty, looked at the board and alot of solder splash and really poor components. If they are real then they probably didn't pass any type of QC approval, resistors look like they were made by a 5 here with playdow and so called mkp caps have such poor printing that I doubt if they are real.
Any help is appreciated,thanks.
__________________
Nakamichi pa-7II, ca-5,st-7,micromega tempo 3
Micromega stage1& stage 3, AA ddsIII
Ls3/5a,Marantz HD-880, Infinity rs3b
Sony Ps-x70, Pioneer pl-630, Technics sl-1100a
Harmon Kardon HK400XM,luxman k8,Pioneer ct-f1250
  #2
Old 01-29-2013, 12:53 PM
gil41 gil41 is offline
AK Member
I have and been using this preamp for more than six months now and so far so good. For the schematic, I contacted the factory directly and was given an old schematic which they said is still applicable. I am attaching it here plus answer I got when I requested it. Contact info: xshn@xshn.com and Spencer was my contact. I've done only some tube rolling and I only hear some sort of hum when my speakers are so close (about a foot when testing some speakers) to it. I am a mechanical eng'r with very limited electrical/electronics background; thus, the schematic is only for a tech use in case I have an issue.
I had an initial look when received and the boards and soldering in mine (I've done basic soldering only) looked ok. Please let me know what upgrade you will make on the components and could serve as a guide for me when I am ready for the component changes (caps, etc.).
" Hi Gil,
For the latest 728A preamp, we adopts the 12AU7, 12AT7 tubes. The schematic diagram is the old one, but could use as the reference for the latest preamp. Because we do not make so many differences.
Have a nice day!
Spencer"
  #3
Old 01-29-2013, 05:41 PM
KenP's Avatar
AK Member
I think mine is an older version, it doesn't have the large paper in oil russian caps instead it has the standard chinese mkp copies. I also noticed that it has a really big channel imballance. I got it cheap enough that I think I'll replace all the caps and all the resistors plus the volume pot, looks like an alps unit will fit right on the pcb.
__________________
  #4
Old 03-01-2013, 01:38 PM
newbee123 newbee123 is offline
AK Member
any one doing mods already?
I just change the tube ....
  #5
Old 03-01-2013, 01:54 PM
AK Member
Here what I got from xiang sheng
Audiokarma
  #6
Old 03-01-2013, 02:42 PM
KenP's Avatar
AK Member
I changed all the caps panasonic for the big ones some silmic on the inputs and mundorfs for the bypass on the tubes, changed all the large resistors, some of the originals a way out of spec. changed the volume for an alps blue velvet, changed the wiring for the outputs to teflon coated silver wire. Thats about it for now, still no time to really listen to it.
__________________
  #7
Old 03-01-2013, 03:07 PM
NOSValves NOSValves is offline
AK Member
I bet the changes you made will have a huge improvment if properly implemented...
__________________
NOS Valves NBS Preamplifier l NOS Valves VRD mono blocks l Sota Jewel w/RB-300 & Denon DL-103R l Sony SCD-333ES CD/SACD l Radio X Tuner modified Sony l Modified Lascala Baby (known world wide as Frankenscala)
http://www.nosvalves.com/images/engrave2.jpg
  #8
Old 03-01-2013, 08:11 PM
KenP's Avatar
AK Member
DSC_2507.jpgHere's a pic of the internals.
__________________
  #9
Old 03-01-2013, 08:15 PM
KenP's Avatar
AK Member
Has anyone taken out the pcb for this pre? I need to know where the led for the power is connected on the bottom of it.
__________________
  #10
Old 03-02-2013, 12:21 AM
AK Member
Quote:
Originally Posted by KenP View Post
Attachment 413985Here's a pic of the internals.
I think your and mine is little bit different
Audiokarma
  #11
Old 03-02-2013, 06:16 AM
KenP's Avatar
AK Member
Mine is an older model before they used those large russian paper in oil caps. Look on the net for pics of the 728 and you'll see it. Aside from those caps only real difference is the pcb is split just behind the tone/volume/switching section.
__________________
  #12
Old 03-02-2013, 07:30 AM
AK Member
I'd be upgrading every single part on that main circuit board carefully using parts for the Sonic benifits if it was mine. That parts on that board are like most Chinese made gear inexpensive crap. The nice thing about this piece is you have plenty of room to work with...
__________________
  #13
Old 03-02-2013, 11:20 PM
AK Member
Quote:
let me know what is your upgrade and pls share it
tks
  #14
Old 03-06-2013, 06:53 PM
AK Member
It seems that what on the schematic is not the same with actual product.
So many different after I trace out
  #15
Old 03-06-2013, 07:01 PM
KenP's Avatar
AK Member
There are many differences on the schematic, don't use it as a reference.
__________________
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Audio by Van Alstine
Capacitor World
AudioFriends
Meistertech Solutions
Vintage Home Audio
Okki Nokki
Analog Engineering Associates
Wargos Electronics
Organ Donor Parts
Hudson Valley Hi Fi
Sound Stage Direct
Take Five Audio
Parts Connexion
Howard Products
Simply Speakers
Audience AV
Amplifiedparts
AudioClassics
The Tube Store
Audio Doctor
RSL Speakers
Many Moons Audio
DeWick Repairs
BOI Audio Works
Yesterday's Audio
MCM Electronics
Videokarma.org
Politicalchat.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
