I found this Roberts 770x EL84 tape unit a year ago and had it sitting around for awhile and I finally got around to it
I have read the threads about pulling the mono amps and converting them for stand alone use. I do not mind people doing this but since I got the unit working so well and I love tube gear I decided to keep it and use it intact
It powered up but would not play, so I ordered a new belt. But it was just the complicated operating procedure that was why I couldn't get it playing.
Once I got it playing one channel did not work.
I got the service manual and pulled it apart, cleaned/lubed the transport and noted the belt and tires were excellent
Tested the tubes, caps and resistors, used a bunch of deoxit and after messing around with it I got both channels working
It sounds great, no hum, nice and clear
It has original tubes, NEC and Toshiba EL84's
I am glueing one screen panel so it is missing in the picture
I am thinking of having the case veneered in walnut
