I have read a lot of threads and still end up with a ton of questions. I sure hope you wizards can help! (apologies for the long post)
I have been trying out SET amps and love the sound. my favorite so far is the clementine darling I received from Watt in a trade. I have a simple tombstone style OB that someone kindly gave me. Have 3 full range drivers so far: visaton B200s with phase plug mod; betsys (from opa1) and radio shack 40-1286c (from mfhale). I'm thinking about getting other drivers; eg, EV LT-12s, maybe some old Jensens. the eminence betas that poultrygeist likes might also work.
now I want to build a larger OB. per suggestions from opa1 and others I first built several baffle designs with cardboard and rigid foam board. 1st the wild burro labs betsy enclosure: http://www.wildburroaudio.com/projects.php. 2nd I made the classic JE Labs OB: http://jelabsarch.blogspot.com/search/label/Open Baffle. last i tried a smaller winged baffle design: center panel 16" x 36" and two side wings each 12" x 36".
my listening room is about 10' x 13' and my cardboard OBs are placed right now about 7.5' from my listening position.
all 3 enclosures sound pretty good. the betsy design is just huge in this room so doesn't make sense. that leaves me with the JE Labs or the smaller winged baffle. I think I had better imaging with the JE Labs enclosure but am not positive.
Questions:
1. I tried the "edge" baffle design software. I used the JE Labs baffle and a 8" driver for my modeling. I get really messy looking curves unless i move the driver to very close to the edge of the baffle. (Still kinda messy anyways.) Does this make sense? Joseph Esmilla (of JE Labs) says the drivers should be offset but seems to say that offset needs only be slight. does the edge software really fit with the slanted JE Labs baffle design? how much offset should I use?
2. Given my objectives and room, does anyone have suggestions for me re baffle design? either amongst the 2 i have narrowed it to or any other design. my cardboard building has confirmed to me that I should stick with simple designs and I don't have the competence to build crossovers, etc. I am hiring a friend to build these baffles, that is how bad I am at doing it myself.
3. I want to be able to switch drivers pretty easily. so the idea is to have a cut-out in the main baffle and several inserts that would fit in the cut-out. the inserts would have the drivers mounted so drivers could be switched. my builder suggests it would be safest to screw in the inserts to prevent vibrations. i am wondering if an easier on-off is possible. what about using mounting hardware like these trunk clasps: http://www.homedepot.com/h_d1/N-5yc...keyword=draw+latch&storeId=10051#.URqHVx27PIU
any thoughts about whether that would work?
4. any suggestions re wood, finish, or anything else would be appreciated...
Thanks for any ideas!
Questions:
