arcorob
Addicted Member
Audio Technica LP120 USB Professional Direct-Drive Turntable
All I can say is ...wow.
From AMAZON
Received the replacement today, setup was 10 minutes. The cart was pre-mounted but of course the overhang and angle was off. I used a normal Baerwald protractor and the famous Mirror Protractor sold on BT. Perfect alignment,
So I set it up and tested here out. Sweet. Noiseless, smooth operation. The speed stays rock steady in either quartz lock or manual. The only drawback, they should have an indicator light to tell you if you are manual or quartz lock. The only way you know is if you move the slider. If the table reacts, you aren't in quartz lock.
All adjustments are precise and easy to work. From balancing to VTA and the arm leaves the cart azimuth perfect.
I spun one of my favorite test albums (Captain Fantastic) and even with the $49 AT95E, it sounded wonderful. I tried the speed controls and even the reverse button. Stop brakes stop on a dime.
Okay, so then I took the needle off the album and turned the received volume all the way up. DEAD SILENT. No hiss, no hum. Wow. Its running in LINE IN mode using the internal pre-amp
I like it so much, I have a dilemma. I may just want to keep this home and bring either my Dual or my self built table in to work...Only issue is this.
The Dual has an AT150MLx. The self built, an MC cart ATOC9/III. What do I move where ? I was thinking put the AT150MLx on the Audio Technica TT, the MC cart on the Dual but it would be a crime to put an AT95E on my self built table. You've all seen that thing and the high end arm...I would get another cart, maybe a nice ADC but still..decisions decision.
Solid thumbs up to this table, and based on other tables I have used, compared, including Technics (no, no SL-1200) I would hold it up in a shootout. I'll know better when I try the AT150MLx on it.
Pictures ...we all love pictures !
From AMAZON
