Brett a
~◦●○o0o○●◦~
Hi all.
As some of you know, I just bought new speakers. My first set of stand mount/monitors.
I the pair I had on loan were mounted on the correct stands, Focal s800 to be exact.
I just couldn't see paying $325+ for these wonky MDF and plastic things, so I decided not to buy them but rather build my own.
While I had them in my possession, I took photographs and measurements, did some thinking and proceeded to build my own.
Right now, they are at the stage of useability, although I still have to paint them, drill mounting holes to bolt the speakers on them (the cabinets have tapped holes to screw them to a stand), and fill them with sand or lead or cat litter (or a combination thereof).
So, you can maybe see from these pictures that I overbuilt them compared to the stock jobbers.
I decided to go with a pair of threaded rods in each for integrity. I'll write more later, but for now, enjoy some pictures (or don't)
The official picture of the real Focals:
There are no common angles on the posts. The side walls come off the back plate at 5 degrees each (a 10 degree "V") and the front point involves angles that I just carried from original to plans w/o checking the actual numbers (the table saw I was using is not in tune enough to trust its gauges, so I eyeballed many of the setting).
I glued the posts up in sections.
The underside of the footing. This panel is the same size and shape as the speaker its self. You can see the star nuts embedded in the MDF. This is to mount the threaded rods. I just put standard furniture feet on it for now. It'll get spikes eventually.
Let's call these the Johnson rods, OK?
The nuts near the top are nylon lined and are there to keep me from reefing down too hard on the caps (you'll see that later)
