Wigwam Jones
Caesar non supra grammati
I have started a new thread on this, since it came up on a discussion about a particular cartridge and stylus. I think it is a more general type of question, though, so here's the new thread.
The comment was made by several people that if you use a tracking force that is too light, you risk damaging your records. In fact, the assertion is made that too little VTF is worse for your records than too much.
The two reasons I have heard so far are these:
1) If the VTF is too light, the needle may skip in the groove, which causes damage.
2) If the VTF is too light, the needle may 'rattle around' or 'vibrate' inside the groove, causing damage or excessive wear.
I can fully understand why mistracking is bad. But if your record is skipping, you can hear it. This goes all the way back to the bad old days when my parents would put a penny on the end of the tonearm when a record got old and damaged and started skipping. No problem grasping this concept.
However, I am not sure where the concept came from that you can damage your record by using a lighter-than-recommended tracking force even if it is NOT skipping.
Certainly, I read this a lot. I can Google and find references to this recommendation and reasoning on any number of discussion forums. But I'm not sure it's based in reality.
In an effort to try to track this down (no pun intended), I found these:
http://www.ortofon.com/support/faq-installation
Ortofon makes it clear in their FAQ that wear is caused by mistracking. But again, this is something you can hear. Your needle either is or is not skipping, right? Or do they mean something else by the term 'mistracking'? I'm unclear on this.
http://shure.custhelp.com/app/answe...sion/L3RpbWUvMTM2MzYxMjk1OC9zaWQvZWpDOG10bGw=
Shure seems to feel that 'the lighter the better'. But they also state that a cartridge / stylus has a given range for VTF, and this should be observed. So, the 'lighter the better', but within the manufacturer's recommended VTF range, presumably.
But I'm still not finding any information regarding the stylus rattling around in the groove and causing damage if the VTF is too light, unless that is what Ortofon means by 'mistracking' causing damage.
Does anyone have any other information that might shed some light on this question?
3.2. Distortion
Correct tracking force is very important for optimum performance as well as for reduction of wear in the record caused by mistracking. Tracking force should rather be too high than too low to overcome high amplitudes in the record and should be adjusted together with the anti-skating.
Tracking weights
Published 07/08/2001 06:31 PM | Updated 09/30/2008 08:22 AM
QUESTION:
My question is a very simple one but I didn't find anything about it in the quick look I had on your pages. I have a Sansui turntable (SR-212) which I bought second hand and so I don't have the manuals. Its arm has a variable weight system. As I could find from some testings, if the arm weight is too low there will be distortions in the sound; if the arm weight is too high I supose it could damage the records grooves and the needle. So my question has three parts: 1. what's the ideal weight for playing a typical record in good conditions with a new needle? 2. what's the acceptable weight range in order not to get any distortions nor damage records in the long term? 3. is it true that older records tend to demand higher weights?
ANSWER:
1) What's the ideal weight for playing a typical record in good conditions with a new needle? * This depends upon the phono cartridge mounted on the tonearm. Tracking weights range from 0.75 grams to 5 grams.
2) What's the acceptable weight range in order not to get any distortions nor damage records in the long term? * The lighter, the better. One gram is a good choice IF your tonearm/phono cartridge combination can track at one gram.
3) Is it true that older records tend to demand higher weights? *78 rpm records require a higher tracking weight than 45 rpm records. 45 rpm records require a higher tracking weight than 33 1/3 rpm records.
Answer ID 1356
QUESTION:
ANSWER:
Answer ID 1356
