Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Tube Audio
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 03-31-2013, 07:53 PM
tomam17 tomam17 is offline
AK Member
Malfunctioning Yaqin SD-32A tube CD player
Hey everyone- not sure if I'm putting this in the right forum.. but here it goes:
My 5 month old Yaqin tube CD player with RCA 6SN7GTB tubes is having some issues. About 3 weeks ago, I was listening to a disc, and the music turned to pure static...
-Tried another disc, pure static.
- Powered the unit down and tried again the next evening.. managed about 25 minutes of music until the static kicked in.
- Powered down the unit and tried again the next afternoon.. this time, I moved the unit off my shelving unit and put it in a nice open area thinking it could be overheating. Static kicked in about 20 minutes in to a disc.
-Next day, I put the stock tubes back in, and managed an entire day of music without static! Managed about 10 discs over the course of the next week as well with no issues.
-Today, I managed about 50 minutes of music, and the static was back.
Could hot tubes caused the internal DAC to overheat or something to this effect? It does not feel abnormally warm, but heat is the only factor I could think of that would cause a CD player to sporadically malfunction. Really stinks.. this thing produces some fantastic sounding music
Thanks guys!
__________________
-Pro-Ject Debut III (Speedbox II, Acryli-It, Bren1 Weight, Ortofon Super OM30)
-Bottlehead Seduction (Tesla E88CC)
-Yaqin SD-32A CD Player (Sylvania 6SN7GTB)
-Apple iBook G4 PowerPC (In place of OTA radio)
-Yaqin MC-10L (6N1P-VI, 6P3S-E)
-Altec Segovia
  #2
Old 03-31-2013, 08:01 PM
hjames's Avatar
hjames hjames is online now
Lady Audio-buff ...
Location: NoVA, 22030 - somewhere on the outskirts of DC
6 months old isn't much - Is it new to you, or did you buy it used?
If new, have you written the seller/vendor and asked them for support?
__________________
#1 - [2ch] Airtunes or Oppo 981HD; Denon DP45F; Jolida 502 BRC ; UREI 811C, Von Schweikert VR4, Vandersteen 3A, 2CE.
#2 - [HT7]  XDA-2 DAC, Oppo BDP-93, Integra DTC 9.8, B&K AV-5000 II Amp; 2 pair UREI 809A, Vandersteen VCC1, DCM TF600 (rears), & JBL 4641 (18" sub)
  #3
Old 04-01-2013, 08:14 AM
stanko's Avatar
stanko stanko is offline
Hoarder
Sounds like a power supply issue. A bad solder joint or a bad part that overheats and opens. Are the tubes lit when the static starts? That would eliminate filament supply problems. The reason I ask this is because the Chinese units have small power supplies and when switching tubes some of the old USA types draw too much filament current. I know this from experience, a Shanling CDT-100 that came my way had a completely fried filament supply because of tube swapping. A hole was actually burnt through the board where the original diodes were mounted. The diodes didn't fail, but the board failed completely, burnt board, fried tracings, etc. Put the original tubes in, take it apart, and when the signal disappears start tapping individual components with a small pencil like stick. I wouldn't be a bit surprised if you found the problem.
__________________
12 feet of electrostatics, my stereo.http://www.audiokarma.org/forums/sho...d.php?t=499437
  #4
Old 04-01-2013, 08:28 AM
wa2ise's Avatar
wa2ise wa2ise is offline
AK Member
Quote:
That's what you'll hear when the sample bits get mixed up. Something in the digital circuits is messing up. Could be a bad solder joint somewhere in the digital section of the player. Flexing the board while playing a CD might make it come and go. Resoldering all those connections may clear it up. Though I'd stay away from surface mount chips, unless you can skillfully handle a soldering iron around them without creating shorted pins.
__________________
  #5
Old 04-02-2013, 12:52 PM
phaelon56 phaelon56 is offline
AK Member
I received my SD-32A just yesterday and so far so good Did you buy it on ebay from Song Gao - the guy in the Toronto area? He has been very responsive to my questions and is certain to offer advice, assistance and if necessary even replacement parts. I know that some of the Chinese audio gear has very small power supplies but the reading I've done about this units suggests that this model is different. I ran it for five hours yesterday and it barely got warm.
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Meistertech Solutions
Capacitor World
AudioFriends
Analog Engineering Associates
Vintage Home Audio
Okki Nokki
Hudson Valley Hi Fi
Wargos Electronics
Organ Donor Parts
Parts Connexion
Sound Stage Direct
Take Five Audio
Audience AV
Howard Products
Simply Speakers
The Tube Store
FM DX Antenna
AudioClassics
Many Moons Audio
Audio Doctor
RSL Speakers
Yesterday's Audio
DeWick Repairs
BOI Audio Works
Politicalchat.org
MCM Electronics
Amplifiedparts
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
