srb02
"Infinity Speaker" Man Cave
Rookie builder need help. Waiting for my UL OPT's and power transfo to build a Kegger SEUL amp,
so figured to throw together a rh84. "for practice"
problems are:
very weak/low sound, if increase volumn on preamp it starts clicking, and the louder you go, the louder and faster the clicking gets, until it turns into a screaming/screeching whail.
if you start up amp w/ out the pre-inputs connected, these sounds/screeching starts immediately. Rechecked all wiring, twice. rechecked all resistor and cap values, twice. Have tried a different set of tubes.
tube pin violtages:
6bq5
1: 8.3
2: -27.8
3. 4.0
7: 321
9: 278
12at7
1: 196.6
2: .6
3: 1.28
I know the B+ is a little high, at this measurement, I am using a Variac, and it does the same thing at 300V.
Also the 250ohm resistor from pin three to grd on 12at7 is 240.
270ohm 5 watt pin 3 6bq5 is only 250 ohm. this is what i had, and the difference is almost within the 5% tolerance.
any help thoughts would be most appreciated.
I can upload some pics tonight.
Is my mistake right in front of my face?
Thanks in advance Stu
problems are:
tube pin violtages:
6bq5
1: 8.3
2: -27.8
3. 4.0
7: 321
9: 278
12at7
1: 196.6
2: .6
3: 1.28
