Dandy
Addicted Member
I finally got my small SE amp with one 12AX7 and one 6BQ5 per channel separated from tone and balance network and rigged up as a power amp with a passive pre.
Now, I'm puzzled to find that one channel is missing its HF. It sounds as if the tweeter on one speaker is out. It's not the tubes, as I've checked with good replacements. I hadn't noticed this as I was using unmatched junk speakers for testing. But I've tried it now with two good pairs and the results are the same. It also sounds out of phase!
This is a new fault to me. Can anyone please tell me where to look? Could it even be the transformer? The amp has quite a small component count and I've checked all values and connections for touching wires, etc. I've removed the tone, balance and volume pot from each channel and the signal now comes in direct to the grids of the 12AX7. I attach the circuit.
Any thoughts, or similar experiences?
