Ok, I do not normally get over enthused, but SET12 mods to the Klipsch Forte is insanely over the top. And, this is 'out of the box'- no capacitor break-in. Plus, the original crossovers have the SoniCraft capacitor upgrade with Erse 47uF bass shunt capacitor. To make sure there is no question here, I installed one crossover at first and two of us listened in mono & switched the balance control from one side (new x-over) to the other side (stock x-over). Of course, after installing the second crossover stereo was a knock out.
First, the SET12 crossover opens up details effortlessly- across the board.
The bass is now tight and fast. I did not think the bass was a little muted & not precise before. Now, Klipsch bass is clearly in another level of performance. Simply no comparison.
The midrange is also improved. Details come forth in spades, yet not the least bit edgy even with a horn. The midrange is so much improved- very musical, airy and accurate. The old crossover is simply dead. (The best tap on the German C core audio transformers with the 1.5 dB tap steps is #5. #6 tap is a little bright on some record passages).
The tweeter I have is a Crites titanium. So, not poor in the least with old crossover with SoniCraft caps. However, with the new crossover it has improved too.
I have owned a few speakers including higher-end Scan Speaks. Scan Speakers are not muddy sounding in the least. With the factory stock Forte I liked the dynamics of horns, but some micro details were not there. That is completely untrue now.
I have no idea what a different speaker set would cost that could compare with these upgraded Klipsch Forte. The $750 crossovers are worth evey penny. SET12 is right, I have no interest hearing a stock Klipsch Forte either now.
Thank you SET12 for all your work tuning these Forte speakers. What a class act. HeYah.
