tomlinmgt
Lunatic Member
And boy, was it every bit the bitch they say it is. I definitely have some better construction methods/techniques in mind for the second one. As a matter of fact, I'm not even going to detail the build yet as I see much room for improvement in that regard.
All that having been said, here it is...my third go at diffusion (but my first go at proper diffusion). My first two panel designs were rather "shotgun" in approach but did provide a positive contribution to room/speaker interaction. This go 'round I decided to get serious and sat down with QRdude and started running lots of different calculations. I settled on an N13 design (13-well) that covers all the critical mid range (and then some) and offers true diffusion at five target frequencies (only the more expensive commercial panels accomplish this).
This design has a usable frequency range from 415 Hz to 4526 Hz (scattering from 415-831 Hz) and true diffusion at 831, 1662, 2493, 3324, and 4155 Hz. It can also be used as close as four feet to the listening position so it's a great panel for large or small listening spaces. 1D well-type QRD diffusers will also offer some LF absorption by virtue of the design and the Dow foam insulation board I used is absorptive from around 350 Hz down.
I plan on building three for the front wall and three for the rear wall and perhaps a few for each side wall. If I stay on schedule I should have them completed, oh, I don't know...before the rapture, maybe. I'll share my recipe if I can get the construction method sufficiently refined it becomes doable for your typical DIY-er in less than the seven hours this one took. Oh wait, make that eight hours since I still have to paint this one. :sigh:
- Michael
- Michael
