audiozaz
rtfm!? - tl;dr
Built over the same three-day weekend as the recent DBR fullrange, here is my third brush with CD speaker building. Midbass is a Peerless 830869 8" Nomex-cone in a ~53L tower reflex, better known as a mass-loaded transmission line, MLTL. I'm using a 3" Precision Port. HF is handled by a BMS 4540ND 1" compression driver mounted on the small 6"x6" JBL progressive-transition waveguide. Here are the drivers:
Here they are on my #2 CD project, now sporting its phase-plug, for a few months now:
From the spec sheet response of the Peerless midbass, it looks like it would be suitable for a ~2kHz crossover to the small HF driver, which I think should hold directivity close to that. My actual measurements will tell me the exact story. Worse case, I'll have a small pinch in this area.
Here is a naked enclosure and one with everything mounted:
Construction is fairly simple, butt-jointed 18mm BB-ply with a holey brace down the line and a dowel brace between both drivers. External dimensions are 37.5" height, 13.5" width and 9" depth. I went for a ~golden ratio internal cross-section. Finish is simply waterborne varnish, as I wanted to keep the wood as light as possible to contrast the black drivers and port. I'm using Neutrik Speakon connectors on this one, wanted to try these for a while.
Having one speaker assembled, I'll begin taking some measurements to begin work on the crossover. I'm thinking of using a Crites 3636 autoformers to pad-down the much more sensitive compression driver and already have a crossover layout figured out for that, with staggered impedance at every stage via swamping resistors, thanks to a massive impedance boost at the autoformer primary. I'll post more as things progress.
az
az
