Marantz 4400 Restoration Notes and Questions
watersgate
So thanks to all of the great info on this board I just finished my first pass at restoring my 4400. It now sounds absolutely incredible. IMHO it's the best sounding stereo I've ever owned or heard. :music:
I'll post some pics soon. First I wanted to share a few notes and ask a couple of questions.
Generally speaking, I used FC/FM caps in the power supply and SILMIC II's elsewhere. Many of the original caps were leaking, including in the power supply and the MPX board. It sure sounds better now. I noted the following discrepancies between the service manual and schematic, and what was actually in the unit:
CH05-CH08 (Filter Amp) - schematic shows 4.7uF 25V, actual was 4.7uF 35V
C513-C514 (Vari-Matrix) - schematic shows 3.3uF 50V, actual was 1uF 35V
C304 (MPX) - schematic shows 10uF 16V, actual was 22uF 16V
C250 (FM I.F.) - schematic shows 10uF 16V, actual was 22uF 16V
I used the values shown in the schematic because that's what I had on hand. As mentioned, it sounds great. But I am tempted to plug in the alternate values to see if there's any discernable difference. My model was made in '77, so my guess is that these were tweaks that were made to the design over time but never updated in the manual or the schematic. But who knows...
Also, these caps are shown as polarized in the schematic, but the actual caps were nonpolar:
C401 & C402 (coupling caps on Phono Amp)
C307 & C308 (LPF caps on the decoder IC)
Again, I used polarized caps because that's what I had on hand. My research shows that the common wisdom is that these should be replaced with nonpolar film caps - curious if anybody has a different view, though. As mentioned, it all sounds incredible, including the tuner and the phono stage. So I'm not sure whether to bother changing them out again.
Just a note, for the 1000uF cap in the power supply I used this, it was very expensive but all I could find, and the specs on it are great:
Newark - 98K6827 MAL212018102E3 (Vishay BC)
I used the same filter and bypass caps shown in marantzfan's 4400 restoration thread (which was my main guide for all of this). I also replaced and raised the 150 ohm resistor, I replaced 3 film caps on the power supply that were bubbled from the heat, and I replaced three zeners on the board too. It is rock solid at 35.0 V now.
Question: you guys helped me fix a problem on the power supply that I believe was caused by inadvertently shorting the 35V supply to ground while working on a different board. Both before and after the fix, the power supply has worked perfectly. All the output voltages are perfect. But, there's one (and only one) voltage on the board that is curious...the collector on H811 reads about 46V, while the schematic shows it should be 34V. The H811 emmiter is correct at 13.4V and R802 and R803 measure correctly. So I wonder if maybe it's an error on the schematic? Just sort of bugs me that the board is working but that one value is off. Would love to know if anybody else has a reading on that voltage to compare.
Well that's it for now. Next up is to replace the lamps. I still haven't figured out how to get to them...and I'm considering recapping my SQA-2, has anybody tried that?
Dave
Just a mild increase in front-back separation. Some of the caps are packed tightly on PCB.
camman
Here are some of the boards I recapped. I ended up replacing C401, C402, C307, and C308 with nonpolar ECQ caps. I think maybe it made a slight improvement. But the polar caps, aligned as shown in the schematic, did work fine.
Thanks to everybody on these boards for sharing your knowledge and helping me with the power supply. There's no way I could have done this without this forum. And BTW it was a *lot* of work and I learned a ton along the way!
Next I'll post a few pics of my 4400 all put back together, looking and sounding sweet. :music:
And here's my 4400 all done and sounding incredible.
Really nice
These receivers are the most listenable ones ever made. Its in my LR system and gets used a lot. I replaced a Pioneer SX 850 that replaced a Pioneer QX8000. They were not played much. Weeks and months would go by. Not so with the 4270. Got this free. God they are good. Enjoy it,it's a sweat ride:D
Eric
There was a production change. I don't believe the scope itself it blue, they used a blue filter I believe to provide the blue look.
Hi to all, I'm a new member here. Could you help me with finding parts for my Marantz 4400, please?
I need:
H009 - HD2001008 Diode, 1S2724S
H010 - HD2001108 Diode, 1S2724R
1414 - 290426701, Heat-Sink
1415 - 51380306T, B.H.M. screw x 5
1416 - 51100310E, M.H.M. screw x 4
1417 - 54050300R, T.L. Washer OR, 5x
1418 - 121000501, Clamper
J027 - YJ0500017 Socket, for rectifier
J028 - YJ0500017 Socket, for rectifier
It's missing in my receiver and it's nearly impossible to get them in my country:(
I add pictures for sure, it's the one I need.
Thanks for any help!
Nice work on your 4400.
That is correct.
My Marantz 2130 tuner has the "Green scope." A few years ago, a fellow AK member dropped off his 2130 for repair. Blue scope.
I need:
I think you can replace these with something like a 50amp bridge rectifier or similar. Some other people have replaced them with MUR1620 and Mur1620R...
That should get it going but you really need to replace all capacitors and check all conponents on power supply board as well.
I had one, price out the door was something like $1250 if I recall. I first had it hooked to 4 JBL L-26 Decade Speakers, then onto 4 JBL L-65 Jubal. I still have the Jubals.
I believe I had the TEAC 3340S at the time? Table was Pioneer PL-51 with Shure V-15 III, and AT-14S Cartridge.
We'd be trippin on the scope like we were on acid! LOL Alice Cooper, "Sick Things" in discreet quad.
I still have my Koss 2+2 Quad Headphones, look and play like new!
