Pioneer tx-8100 restoration
guest111
I'm in the process of restoring a tx-8100 tuner to go with my sa-8100 amp. I have the below cap/transistor list from the service manual. Any tips for suitable replacements (particularly regarding transistors)?
I've read the posts on here regarding this tuner, which will definitely be useful in getting it going - I've not seen a complete parts list, so hopefully this thread can help some others too!
Here goes:
Tuner assembly AWE-023-0
Capacitors electrolytic
c21 4.7 25v
c23 10 16v
c24 0.47 50v
c31 1 50v
c32 0.47 50v
c33 0.47 50v
c36 100 16v
c37 4.7 25v
c39 10 16v
c46 4.7 25v
c47 47 6v
c51 0.1 25v
c52 220 16v
Transistors
q3 2SC717
q4 2SC461-B
amplifier unit AWK-019-A
Capacitors
c1 1 25v
c2 1 25v
c3 22 16v
c4 22 16v
c11 100 16v
c12 100 16v
c15 4.7 25v
c16 4.7 25v
c17 1 25v
c18 1 25v
c19 3.3 25v
c20 3.3 25v
c21 100 35v
Transistors
q1 2SC1344-E or D
q2 2SC1344-E or D
q3 2SA725G or F
q4 2SA725G or F
q5 2SC1344-E or D
q6 2SC1344-E or D
q7 2SA725G or F
q8 2SA725G or F
Muting circuit assembly AWM-039-0
Capacitors
c1 0.47 50v
c2 47 50v
Transistors
q1 2SC945-Q or R
q2 2SC945-Q or R
q3 2SC1318-R or S
Headphone Amp AWM-041-B
capacitors
c1 1 50v
c2 1 50v
c3 220 16v
c4 220 16v
c5 47 16v
Transistors
q1 2SC1344-E or D
Q2 2SC1344-E or D
q3 2SC1384-Q or R
q4 2SC1384-Q or R
Power supply AWR-033-0
Capacitors
c3 220 35v
c4 330 50v
c5 220 16v
c7 220 16v
c8 330 16v
c9 220 35v
c10 47 35v
Transistors
q1 2SC1318-Q or R
q2 2SD313-D or E
If anyone has the service manual, is there anything I've missed? (I haven't included ceramic caps if that makes any difference)
Thanks for any and all help!
tx-8100 tuner electrolytic capacitors and audio / driver transistors list
tuner
AWE-023 c21 4.7 25v cea 4.7 50 647-UPW1H4R7MDD
AWE-023 c23 10 16v cea 10 50 647-UPW1H100MDD
AWE-023 c24 0.47 50v cea 0.47 50v 667-ECQ-V1H474JL
AWE-023 c31 1 50v cea 1 50 647-UPW1H010MDD
AWE-023 c32 0.47 50v cea 0.47 50v 667-ECQ-V1H474JL
AWE-023 c33 0.47 50v cea 0.47 50v 667-ECQ-V1H474JL
AWE-023 c36 100 16v cea 100 25 647-UPW1E101MED
AWE-023 c37 4.7 25v cea 4.7 50 647-UPW1H4R7MDD
AWE-023 c39 10 16v cea 10 50 647-UPW1H100MDD
AWE-023 c46 4.7 25v cea 4.7 50 647-UPW1H4R7MDD
AWE-023 c47 47 6v cea 47 35 647-UPW1V470MED
AWE-023 c51 0.1 25v cssa 0.1 50 ECQ-V1H104JL
AWE-023 c52 220 16v cea 220 25 47-UPW1E221MPD
AWE-023 q3 2SC717 leave alone!! leave alone!!
AWE-023 q4 2SC461-B leave alone!! leave alone!!
af amp
AWK-019 c1 1 25v cssa 1 50 647-UKL1H010MDDANA
AWK-019 c2 1 25v cssa 1 50 647-UKL1H010MDDANA
AWK-019 c3 22 16v cea 22 50 647-UPW1H220MDD
AWK-019 c4 22 16v cea 22 50 647-UPW1H220MDD
AWK-019 c11 100 16v cea 100 25 647-UPW1E101MED
AWK-019 c12 100 16v cea 100 25 647-UPW1E101MED
AWK-019 c15 4.7 25v cssa 4.7 25 647-UKL1E4R7KDDANA
AWK-019 c16 4.7 25v cssa 4.7 25 647-UKL1E4R7KDDANA
AWK-019 c17 1 25v cssa 1 50 647-UKL1H010MDDANA
AWK-019 c18 1 25v cssa 1 50 647-UKL1H010MDDANA
AWK-019 c19 3.3 25v cssa 3.3 50 647-UKL1H3R3KDDANA
AWK-019 c20 3.3 25v cssa 3.3 50 647-UKL1H3R3KDDANA
AWK-019 c21 100 35v cea 100 35 647-UPW1V101MPD
AWK-019 q1 2SC1344-E ksc1845 512-KSC1845FTA
AWK-019 q2 2SC1344-E ksc1845 512-KSC1845FTA
AWK-019 q3 2SA725G ksa992 512-KSA992FBU
AWK-019 q4 2SA725G ksa992 512-KSA992FBU
AWK-019 q5 2SC1344-E ksc1845 512-KSC1845FTA
AWK-019 q6 2SC1344-E ksc1845 512-KSC1845FTA
AWK-019 q7 2SA725G ksa992 512-KSA992FBU
AWK-019 q8 2SA725G ksa992 512-KSA992FBU
muting
AWM-039 c1 0.47 50v cea 0.47 50v 667-ECQ-V1H474JL
AWM-039 c2 47 50v cea 47 50 647-UPW1H470MED
AWM-039 q1 2SC945-Q leave
AWM-039 q2 2SC945-Q leave
AWM-039 q3 2SC1318-R 512-KSC2383YTA
Headphone Amp
AWM-041 c1 1 50v cea 1 50 647-UPW1H010MDD
AWM-041 c2 1 50v cea 1 50 647-UPW1H010MDD
AWM-041 c3 220 16v cea 220 25 47-UPW1E221MPD
AWM-041 c4 220 16v cea 220 25 47-UPW1E221MPD
AWM-041 c5 47 16v cea 47 35 647-UPW1V470MED
AWM-041 q1 2SC1344-E ksc1845 512-KSC1845FTA
AWM-041 Q2 2SC1344-E ksc1845 512-KSC1845FTA
AWM-041 q3 2SC1384-Q ksc2690 512-KSC2690AYS
AWM-041 q4 2SC1384-Q ksc2690 512-KSC2690AYS
Power supply
AWR-033 c3 220 35v cea 220 35 647-UPW1V221MPD
AWR-033 c4 330 50v cea 330 50 647-UPW1H331MPD
AWR-033 c5 220 16v cea 220 25 47-UPW1E221MPD
AWR-033 c7 220 16v cea 220 25 47-UPW1E221MPD
AWR-033 c8 330 16v cea 330 25 647-UPW1E331MPD
AWR-033 c9 220 35v cea 220 35 647-UPW1V221MPD
AWR-033 c10 47 35v cea 47 50 647-UPW1H470MED
AWR-033 q1 2SC1318-Q 512-KSC2690AYS
AWR-033 q2 2SD313-D 512-KSC2073TU
AWR-033 d3 wz-140 512-1N5244B
chassis/misc c3 100 6v cea 100 25 647-UPW1E101MED
MOUSER.COM parts list importer data:
647-UPW1H4R7MDD
647-UPW1H100MDD
667-ECQ-V1H474JL
647-UPW1H010MDD
667-ECQ-V1H474JL
667-ECQ-V1H474JL
647-UPW1E101MED
647-UPW1H4R7MDD
647-UPW1H100MDD
647-UPW1H4R7MDD
647-UPW1V470MED
667-ECQ-V1H104JL
47-UPW1E221MPD
647-UKL1H010MDDANA
647-UKL1H010MDDANA
647-UPW1H220MDD
647-UPW1H220MDD
647-UPW1E101MED
647-UPW1E101MED
647-UKL1E4R7KDDANA
647-UKL1E4R7KDDANA
647-UKL1H010MDDANA
647-UKL1H010MDDANA
647-UKL1H3R3KDDANA
647-UKL1H3R3KDDANA
647-UPW1V101MPD
512-KSC1845FTA
512-KSC1845FTA
512-KSA992FBU
512-KSA992FBU
512-KSC1845FTA
512-KSC1845FTA
512-KSA992FBU
512-KSA992FBU
667-ECQ-V1H474JL
647-UPW1H470MED
512-KSC2383YTA
647-UPW1H010MDD
647-UPW1H010MDD
47-UPW1E221MPD
47-UPW1E221MPD
647-UPW1V470MED
512-KSC1845FTA
512-KSC1845FTA
512-KSC2690AYS
512-KSC2690AYS
647-UPW1V221MPD
647-UPW1H331MPD
47-UPW1E221MPD
47-UPW1E221MPD
647-UPW1E331MPD
647-UPW1V221MPD
647-UPW1H470MED
512-KSC2690AYS
512-KSC2073TU
512-1N5244B
647-UPW1E101MED
Mark,
Thank you for that list.
If I replace all these components, particularly the ones on the tuner board, will I need to re-align the tuner?
yes, but it will be serviceable until then. I think this one avoids anything major - I MIGHT have to talk you through a minor stereo decoder 76khz setting. manually following directions, you should be able to hit it pretty accurately.
of course to get it to full spec - the alignment will be needed - things like separation, some distortion etc,...
